  3. Communication Profiles
communication profiles
By tagmout , 14 October, 2020
Hi Mikko ,
Can You tell us , the comparison of HDLC and IP profile ?
Thank you in advance .
5 years 11 months ago
IP profile (WRAPPER) is used when communicating over TCP/IP or UDP. There is no checksum, begin or end of the frame. This makes the frame size smaller.
tagmout
Thank You Mikko for you
Thank You Mikko for you response,
Can You tell us more comparaison between the two communication profiles .
It's not a simple task and it's not possible to do here. They are quite well described in DLMS documentation. You should check them there.
  • lh
