  3. Clock Object
Clock object
By youserj , 16 September, 2020
Hi, Mikko!
How can I set TimeZone and Status into attribute 'time' of Clock (class_id: 8), not in separated attributes it?
For filling last 3 bytes of datetime struct, ex.: 07 E4 09 09 FF 16 0F 00 FF <80 00 00>.
And what better use Clock_obj.time.value.datetime.tzinfo or Clock_obj.time.timezone?
6 years 2 months ago
You can set the last byte setting status flag to the GXDateTime object.
status = ClockStatus.DAYLIGHT_SAVE_ACTIVE
Skip the deviation:
skip = DateTimeSkips.DEVITATION
Use Clock_obj.time.value.datetime.tzinfo. timeZone is not needed anymore. It's removed for the next release.
youserj
my Thank's.
my Thank's.
in _GXCommon.SetDateTime you must use: d = int(dt.value.utcoffset().total_seconds() / 60) instead:
str:1486 d = int(dt.value.utcoffset().seconds / 60) for negative value of time_zone
