  3. Error TAG In HLS
Error TAG in HLS
By k Anand , 11 September, 2020
Dear Sir,
My query is what is the error TAG the meter should return, if any DLMS client sent Get Request after AARQ while authentication is HLS.
Regards
Sreeman.
6 years ago
Dear Sreeman,
Dear Sreeman,
From the BB:
If the authentication is not accepted, then the result parameter in the response shall contain a non-OK value, and no data shall be sent back.
Some meters are also returning empty octet-string.
k Anand
6 years ago
Thanking you Sir,
Thanking you Sir,
i will try with empty octet-string.
Regards
Sreeman.
6 years ago
In the long-term, it might be better to return a non-OK value.
  • lh
