  3. GuruxDLMSTranslator: Decrypt Message
GuruxDLMSTranslator: Decrypt message
By jjm90 , 3 September, 2020
We want to decrypt a message (HLS2) using GuruxDLMSTranslator.
We configure the parameters in Ciphering tab, but in messages tab the PDU is enctypted.
Could you provide us an example please? See attachment with the screenshot.
Thanks in advance.
6 years 2 months ago
Ciphering isn't implemented at the moment for Messages translate.
Download GXDLMSDirector and use DLMS Translator to decrypt the data. You find it from the Tools menu.
jjm90
Yes, we also tried with GXDLMSDirector but with the same result (see screenshot).
Jesús
Check your keys. The authentication key, block cipher key, or system title is wrong.
When the keys are correct, data can be decrypted.
jjm90
We checked the parameters but now the application shows an error "Invalid System Title".
APDU:
0001003000010020D01E300000000480ADB2B25179C688D435863293B8E144FCE364B72B018DFC88
Parameters:
Client System Title: 534C5653453037313837384C
Block Cipher Key: 6565736C656B616B67736C3036616263
Authentication Key: 6565736C656B616B67736C3036616263
Dedicated Key: 22AE2799EC6B730516920C49F47F35D5
Invocation Counter: 4
Challenge: 7941693612072C6D064338170F3D0527
Server System Title: 474F453030303030
What could be the problem?
Thanks.
jjm90
We changed the Client System Title with length 8 and we could translate the message successfully.
But we use length 12 for many projects, why is it not a valid input?
Thanks.
The system title length is always 8 bytes. DLMS standard defines it.
jjm90
You are right, now we can
You are right, now we can decrypt any message.
Thanks a lot for you great support!!
