  3. Error Build GuruxServer2(c Code Base) In Linux(ubuntu)
Error build GuruxServer2(c code base) in linux(ubuntu)
By gkrishna , 2 September, 2020
I am getting error when I build GuruxServer2 in ubuntu(linux). Please see the below. Even If i change the header file location, I am getting further errors.
lantronix@gopi:~/final/GuruxDLMSServerExample2$ make
src/getopt.c src/main.c
src/main.c:45:42: fatal error: ../dlms/include/dlmssettings.h: No such file or directory
compilation terminated.
makefile:30: recipe for target 'obj/main.o' failed
make: *** [obj/main.o] Error 1
Gopi Krishna M
5 years 11 months ago
Make obj and bin folders.
gkrishna
I have already added those bin, obj directories and the issue is with the header file location it seems, I have build other client, server of dlms without issues after making bin,obj as you said, The issue is only with GuruxDLMSServer2.
Gopi Krishna M
Before start
Before start you need to copy files from development src and include folder to dlms folder.
  • Thomasqto
  • Uka Ibe
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
