  3. ActivityCalendar Reading Error
ActivityCalendar reading error
By Valeriy , 4 July, 2020
Gurux.DLMS.AMI
Hello!
Tried to read ActivityCalendar using Director + Ami and got an exception
System.Data.SQLite.SQLiteException: "SQL logic error
unrecognized token: "'""
6 years 1 month ago
I just checked this and it works without problems.
Check that you are using the latest version from Gurux.DLMS.AMI.
Can you paste generated SQL string here? You can get it if you move the mouse over arg.
What attribute index did you try to read.
Valeriy
6 years 1 month ago
Hello!
Hello!
Updated Gurux.DLMS.AMI
The same error.
About the arg =
arg
{UPDATE GXAttribute SET "Value" = '
Joins: {Gurux.Service.Orm.GXJoinCollection}
Settings: {SqLite}
Where: {WHERE "Id" = 243}
The object is highlighted in the picture. I tried to read it.
6 years 1 month ago
Update GXDLMSDirector to the latest version and try again.
Valeriy
6 years 1 month ago
Updated. But still the same
Updated. But still the same error.
6 years 1 month ago
What you try to update?
Valeriy
6 years 1 month ago
Downloaded AMI from git and
Downloaded AMI from git and Director asked me to update. I confirmed.
One remark - I tried to read ActivityCalender by Director using Gurux.DLMS.AMI.
Valeriy
6 years 1 month ago
GURUX.DLMS.AMI was updated.
GURUX.DIRECTOR was updated.
6 years 1 month ago
I mean what did you try to read or write? What action did you make when this occurred?
Valeriy
6 years 1 month ago
I tried to read
I tried to read ActivityCalender 0.1.13.0.1.255
Marked in the picture. Connected to the meter, selected the object, tried to read it.
Valeriy
6 years 1 month ago
As an example - I tried to
As an example - I tried to read Atbitrator and ActivityCalendar after that.
In ValueController.css in line 110 for ActivityCalendar got error. The same as above.
For Arbitrator arg value looks like:
{UPDATE GXAttribute SET `Value` = '<Array>
<Structure>
<OctetString Value="00 66 0A 00 6C FF" />
<UInt16 Value="3" />
</Structure>
<Structure>
<UInt16 Value="4" />
</Structure>
<Structure>
<UInt16 Value="1" />
</Structure>
<Structure>
<UInt16 Value="2" />
</Structure>
</Array>
', `Read` = '2020-07-06 17:06:47' WHERE `Id` = 212}
For ActivityCalendar (where the error occures):
And nothing more.
6 years 1 month ago
Activity Calendar is now tested with several meters and it works without problems.
Can you read the Activity Calendar with GXDLMSDirector and add trace here. Add just Activity Calendar read trace, nothing more.
Valeriy
6 years 1 month ago
11:31:40 Read object type
11:31:40 Read object type ActivityCalendar index: 2
TX: 7E A0 19 03 0F 3E 20 AB E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 02 00 FA 0B 7E
11:31:40
RX: 7E A0 1B 0F 03 12 3B 75 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:40 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F 50 58 21 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 03 00 22 12 7E
11:31:40
RX: 7E A0 12 0F 03 34 6C C8 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F 72 48 23 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 04 00 2A 5F 7E
11:31:40
RX: 7E A0 12 0F 03 56 78 88 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F 94 70 A1 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 05 00 F2 46 7E
11:31:40
RX: 7E A0 12 0F 03 78 04 40 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:40 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F B6 60 A3 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 06 00 9A 6C 7E
11:31:40
RX: 7E A0 1B 0F 03 9A 7B 7D E6 E7 00 C4 01 C1 00 09 09 43 41 4C 49 4D 50 00 00 00 27 5D 7E
11:31:40 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F D8 18 29 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 07 00 42 75 7E
11:31:40
RX: 7E A0 6A 0F 03 BC B1 7F E6 E7 00 C4 01 C1 00 01 04 02 03 09 01 01 09 0C FF FF 0B 01 FF 00 00 00 FF 80 00 FF 09 01 01 02 03 09 01 82 09 0C FF FF 0B 01 FF 00 00 00 FF 80 00 FF 09 01 00 02 03 09 01 83 09 0C FF FF 05 01 FF 00 00 00 FF 80 00 FF 09 01 00 02 03 09 01 04 09 0C FF FF 06 01 FF 00 00 00 FF 80 00 FF 09 01 02 DC F0 7E
11:31:40 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F FA 08 2B E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 08 00 8A F6 7E
11:31:41
RX: 7E A0 38 0F 03 DE C5 D3 E6 E7 00 C4 01 C1 00 01 02 02 08 09 01 01 11 01 11 01 11 01 11 01 11 01 11 02 11 02 02 08 09 01 02 11 03 11 03 11 03 11 03 11 03 11 04 11 04 EB DF 7E
11:31:41 Read object type ActivityCalendar index: 9
TX: 7E A0 19 03 0F 1C 30 A9 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 09 00 52 EF 7E
11:31:41
RX: 7E A8 89 0F 03 F0 BE 3C E6 E7 00 C4 01 C1 00 01 04 02 02 11 01 01 02 02 03 09 04 07 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 02 01 02 02 03 09 04 00 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 17 2D 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 03 01 02 02 03 09 04 06 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 53 81 7E
11:31:41
TX: 7E A0 07 03 0F 31 34 3E 7E
11:31:41
RX: 7E A0 1C 0F 03 F2 14 C5 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 04 01 00 2B 29 7E
11:31:41 Read object type ActivityCalendar index: 10
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 0A 00 3A C5 7E
11:31:41
RX: 7E A0 1E 0F 03 14 5A 7E E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
11:31:41 Read object type ActivityCalendar index: 2
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 02 00 41 17 7E
11:31:41
RX: 7E A0 1B 0F 03 36 1D 12 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:41 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 03 00 99 0E 7E
11:31:41
RX: 7E A0 12 0F 03 58 06 61 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F B4 72 80 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 04 00 91 43 7E
11:31:41
RX: 7E A0 12 0F 03 7A 16 63 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F D6 66 C0 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 05 00 49 5A 7E
11:31:41
RX: 7E A0 12 0F 03 9C 2E E1 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F F8 1A 08 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 06 00 21 70 7E
11:31:41
RX: 7E A0 1B 0F 03 BE 5D 1A E6 E7 00 C4 01 C1 00 09 09 43 41 4C 45 58 50 00 00 00 C7 FE 7E
11:31:41 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F 1A 06 CC E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 07 00 F9 69 7E
11:31:41
RX: 7E A0 12 0F 03 D0 46 69 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:41 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F 3C 32 88 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 08 00 31 EA 7E
11:31:41
RX: 7E A0 12 0F 03 F2 56 6B E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 09 00 E9 F3 7E
11:31:41
RX: 7E A0 12 0F 03 14 6E E9 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 01 FF 0A 00 81 D9 7E
11:31:41
RX: 7E A0 1E 0F 03 36 4A 7C E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 02 00 8C 32 7E
11:31:42
RX: 7E A0 1B 0F 03 58 65 98 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
11:31:42 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F B4 72 80 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 03 00 54 2B 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F D6 66 C0 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 04 00 5C 66 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F F8 1A 08 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 05 00 84 7F 7E
11:31:42
RX: 7E A0 12 0F 03 BE 3E E3 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:42 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F 1A 06 CC E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 06 00 EC 55 7E
11:31:42
RX: 7E A0 1B 0F 03 D0 25 90 E6 E7 00 C4 01 C1 00 09 09 43 41 4C 44 53 4E 00 00 00 E3 D0 7E
11:31:42 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F 3C 32 88 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 07 00 34 4C 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F 5E 26 C8 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 08 00 FC CF 7E
11:31:42
11:31:42 Read object type ActivityCalendar index: 9
TX: 7E A0 19 03 0F 70 5A 00 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 09 00 24 D6 7E
11:31:42
RX: 7E A0 12 0F 03 36 7E EB E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
11:31:42 Read object type ActivityCalendar index: 10
TX: 7E A0 19 03 0F 92 46 C4 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 02 FF 0A 00 4C FC 7E
11:31:42
RX: 7E A0 1E 0F 03 58 32 F6 E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
Valeriy
6 years 1 month ago
Selected item.
Selected item.
6 years 1 month ago
Your meter is returning hex(000000000000000000) as active calendar name and it was causing this.
This is now fixed. The active calendar name is now empty.
Valeriy
6 years 1 month ago
Thanks for your help.
Valeriy
6 years 1 month ago
Everything is ok using web.
Everything is ok using web. But problem using Director (with Ami).
Director without Ami reads full name of the calendar. But if we start to use Ami for reading - only first two characters.
Picture attached.
6 years 1 month ago
I know the reason for this. We are implementing GXDLMSDirector UI so it can show non-ASCII Activity Calendar names.
Valeriy
6 years 1 month ago
Kiitos avusta!
Kiitos avusta!
  • Connecting to meter using Wrapper
  • DLMS Server / Meter emulation in Golang library
  • Unknown Baudrate
  • negative indexing for custom method/attribute
  • System title
  • obedph10
  • FERRUM 26
  • Splin
  • Carlos Ely
  • Sandeep Bajaniya
