  3. Reading: 0.1.13.0.0.255 - Error
Reading: 0.1.13.0.0.255 - error
By MNN , 17 June, 2020
Gurux.DLMS.AMI
An error occurs while reading an object:
fail: Microsoft.AspNetCore.Server.Kestrel[13]
Connection id "0HM0IGO7SPLU8", Request id "0HM0IGO7SPLU8:00000007": An unhandled exception was thrown by the application.
code = Error (1), message = System.Data.SQLite.SQLiteException (0x800007BF): SQL logic error
unrecognized token: "'"
at Gurux.Service.Orm.GXDbConnection.UpdateOrInsert(List`1 list, Boolean insert)
at Gurux.Service.Orm.GXDbConnection.Update(GXUpdateArgs arg)
at DBService.Controllers.ValueController.Post(AddValue request) in D:\Projects\DLMS\Gurux.DLMS.AMI-master\Gurux.DLMS.AMI\Controllers\ValueController.cs:line 110
at lambda_method(Closure , Object , Object[] )
HResult=0x800007BF
Message=SQL logic error
Source=Gurux.Service
StackTrace:
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<<InvokeActionMethodAsync>g__Logged|12_1>d.MoveNext()
6 years 5 months ago
Can you read this data with GXDLMSDirector and paste bytes here?
Paste only read and reply. Don't paste anything else.
MNN
16:47:53 Read object type ActivityCalendar index: 2
TX: 7E A0 19 03 0F 32 4C 61 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 02 00 FA 0B 7E
16:47:53
RX: 7E A0 1B 0F 03 52 3F 37 E6 E7 00 C4 01 C1 00 09 09 00 00 00 00 00 00 00 00 00 73 B0 7E
16:47:53 Read object type ActivityCalendar index: 3
TX: 7E A0 19 03 0F 54 7C 67 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 03 00 22 12 7E
16:47:53
RX: 7E A0 12 0F 03 74 68 8A E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
16:47:53 Read object type ActivityCalendar index: 4
TX: 7E A0 19 03 0F 76 6C 65 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 04 00 2A 5F 7E
16:47:53
RX: 7E A0 12 0F 03 96 74 4E E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
16:47:53 Read object type ActivityCalendar index: 5
TX: 7E A0 19 03 0F 98 1C 6B E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 05 00 F2 46 7E
16:47:53
RX: 7E A0 12 0F 03 B8 08 86 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
16:47:53 Read object type ActivityCalendar index: 6
TX: 7E A0 19 03 0F BA 0C 69 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 06 00 9A 6C 7E
16:47:53
RX: 7E A0 1B 0F 03 DA 7F 3F E6 E7 00 C4 01 C1 00 09 09 43 41 4C 49 4D 50 00 00 00 27 5D 7E
16:47:53 Read object type ActivityCalendar index: 7
TX: 7E A0 19 03 0F DC 3C 6F E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 07 00 42 75 7E
16:47:53
RX: 7E A0 6A 0F 03 FC B5 3D E6 E7 00 C4 01 C1 00 01 04 02 03 09 01 01 09 0C FF FF 0B 01 FF 00 00 00 FF 00 80 FF 09 01 01 02 03 09 01 82 09 0C FF FF 0B 01 FF 00 00 00 FF 00 80 FF 09 01 00 02 03 09 01 83 09 0C FF FF 05 01 FF 00 00 00 FF 00 80 FF 09 01 00 02 03 09 01 04 09 0C FF FF 06 01 FF 00 00 00 FF 00 80 FF 09 01 02 07 35 7E
16:47:53 Read object type ActivityCalendar index: 8
TX: 7E A0 19 03 0F FE 2C 6D E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 08 00 8A F6 7E
16:47:53
RX: 7E A0 38 0F 03 1E C9 15 E6 E7 00 C4 01 C1 00 01 02 02 08 09 01 01 11 01 11 01 11 01 11 01 11 01 11 02 11 02 02 08 09 01 02 11 03 11 03 11 03 11 03 11 03 11 04 11 04 EB DF 7E
16:47:53 Read object type ActivityCalendar index: 9
TX: 7E A0 19 03 0F 10 5C 63 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 09 00 52 EF 7E
16:47:53
RX: 7E A8 89 0F 03 30 B2 FA E6 E7 00 C4 01 C1 00 01 04 02 02 11 01 01 02 02 03 09 04 07 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 02 11 02 01 02 02 03 09 04 00 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 17 2D 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 03 01 02 02 03 09 04 06 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 02 03 09 04 16 00 47 B2 7E
16:47:53
TX: 7E A0 07 03 0F 31 34 3E 7E
16:47:54
RX: 7E A0 2F 0F 03 32 27 6A 00 00 09 06 00 01 0A 00 64 FF 12 00 02 02 02 11 04 01 01 02 03 09 04 01 00 00 00 09 06 00 01 0A 00 64 FF 12 00 01 47 65 7E
16:47:54 Read object type ActivityCalendar index: 10
TX: 7E A0 19 03 0F 52 4A 02 E6 E6 00 C0 01 C1 00 14 00 01 0D 00 00 FF 0A 00 3A C5 7E
16:47:54
RX: 7E A0 1E 0F 03 54 5E 3C E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF 00 00 FF FF 80 00 FF 94 42 7E
