  3. Dlms Server Example Invalid Data
dlms server example invalid data
By nishitha , 16 June, 2020
hi Mikko,
I have connected my meter and ran the server code,when i run the meter starts sending data, in the server side, data is receiving but it is showing invalid hdlc frame: 10 expected : 54, can you tell me why we get this error and how do i see the actual data(it is in hex form) meter is sending. Also output said server not initialized how do we initialize server
output:
Logical Name DLMS Server in serial port COM8
java.lang.RuntimeException: Server not Initialized.
Press Enter to close.
Invalid HDLC Frame: 10 Expected: 54
6 years 4 months ago
You need to initialize the server. In your reply, you said that you have connected the meter?
If you want to read the meter you need to make a client.
nishitha
1) i donot want the client because i am not reading any meter data.
2) in the server code, there is already server.initialize() again what do i need for server intilization???
Hi Nishitha,
Hi Nishitha,
The server code is if you want to implement DLMS meter. If you are not reading any data what you want to do? Server.initialize function is used when you create DLMS meter.
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
