  3. Event Status Word and Event Code Mapping
Event Status Word and Event Code mapping
By Bhaumik , 1 June, 2020
I am testing the event from IS15959-2 meter. In that, I am able to receive and decode events.
From the received event I can check set bit. From that, I can identify which type of event occurs but not able to identify which event occurs.
e.g if bit no 84 set means "301/302-Meter load disconnected/Meter load connected" event received But is that actual event code is 301 or 302?
How to identify that?
6 years 5 months ago
You need to read Disconnect Control object 0.0.96.3.10.255 and check the state. State value is not save in IS 15959-2. Only status information that the state is changed is saved.
