  3. GXDLMSDirector - Device Setting - Authentication
By deepaks , 22 May, 2020
I cannot see Lowest to HLS-5(Device Setting -> Authentication) authentication level in 8.2.2005.1401 version of GXDLMSDirector, Ijust wanted to do some POC for High Level GMAC based association and Reading.
Am i doing something wrong?
Thanks in Advance
6 years 6 months ago
What device did you try to read? This manufacturer hasn't support GMAC before.
Change device manufacturer to Gurux and update your settings and try to read again.
deepaks
Thanks I got the option now, but when i proceed after filling all the nexessary security details as attached, I got following error in Meters AARE Response(I Guess), but could not able to locate the error, SO need your expert help.
The XML generated as:
<GXDLMSDevice xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns="Gurux1">
<MaximumBaudRate>9600</MaximumBaudRate>
<Authentication>HighGMAC</Authentication>
<Password>mR3Vs57qW5rOSoeFK50bdw==</Password>
<Security>Encryption</Security>
<SystemTitle>45484C3435363738</SystemTitle>
<ServerSystemTitle />
<DedicatedKey />
<BlockCipherKey>45454545454545454545454545454545</BlockCipherKey>
<AuthenticationKey>41414141414141414141414141414141</AuthenticationKey>
<Challenge />
<ClientAddress>32</ClientAddress>
<StartProtocol>DLMS</StartProtocol>
<UseFrameSize>true</UseFrameSize>
<InactivityTimeout>120</InactivityTimeout>
<Name>L500MRHLS5</Name>
<Conformance>6173</Conformance>
<Manufacturer>grx</Manufacturer>
<HDLCAddressing>0</HDLCAddressing>
<UseProtectedRelease>false</UseProtectedRelease>
<MediaType>Gurux.Serial.GXSerial</MediaType>
<MediaSettings>&lt;Port&gt;COM5&lt;/Port&gt;</MediaSettings>
<UseLN>true</UseLN>
<Objects2 />
</GXDLMSDevice>
The Communication loas:
19:39:14 Send SNRM request.
TX: 7E A0 1E 03 41 93 98 5E 81 80 12 05 01 75 06 01 75 07 04 00 00 00 01 08 04 00 00 00 01 25 9C 7E
19:39:14
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 75 06 01 75 07 04 00 00 00 01 08 04 00 00 00 01 25 9C 7E
19:39:14 Send AARQ request.
TX: 7E A0 5F 03 41 10 07 E2 E6 E6 00 60 51 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 45 48 4C 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 43 5D 59 2E 0A 12 5F 60 42 18 79 28 58 61 17 0B BE 17 04 15 21 13 20 00 00 00 00 06 E9 1B 05 31 31 23 B9 C9 C1 79 A0 59 58 8A F5 7E
19:39:14
RX: 7E A0 7E 41 03 30 F5 96 E6 E7 00 61 70 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 FB 62 AD 3E FB 62 AD 3E FB 62 AD 3E FB 62 AD 3E A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 48 4C 34 35 36 37 38 BE 17 04 15 28 13 20 00 00 00 0A 1D 65 F9 D1 D4 7F 64 46 7E AB 34 59 F5 93 BE 2C EB E6 C7 BC 45 35 CC CF 5B C6 EF B0 45 82 B9 A2 85 F6 30 7E
19:39:14
RX: 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
The Promp file is attached
There is unknown tag in the data. I believe that you are adding extra bytes in ciphering to the data.
deepaks
Yes you are right it was due to corrupted buffer.
Thanks a lot.
Hi Deepak ,
Hi Deepak ,
I'm glad that this is solved and you let me know the reason.
deepaks
In reply to Hi Deepak , by Kurumi
My new implementation was extra incrementing the response buffer index by Size of Security header and Ciphered Content which the code has already taken cared of.
Thanks for your Help !!!
