  3. Activity Calender Read - DayProfileAction Is 0
Activity Calender Read - DayProfileAction is 0
By Mohanraj , 16 May, 2020
This is another thread where am unable get proper DayProfileAction scriptLogicalName and scriptSelector after reading the data values are 0s
Below is the code snippet
printf("Reading Activity Calendar...\n");
//const unsigned char ln1[6] = { 0,0,10,0,100,255 }; //script
const unsigned char ln[6] = { 0,0,13,0,0,255 };
gxActivityCalendar activityCalendar;
if ((ret = cosem_init2((gxObject*)&activityCalendar, DLMS_OBJECT_TYPE_ACTIVITY_CALENDAR, ln)) == 0)
ret = com_read(connection, &activityCalendar.base, 9);
gxDayProfile* dp;
gxDayProfileAction *dpAct;
gxArray *arr;
int pos, pos2;
for (pos = 0; pos != activityCalendar.dayProfileTablePassive.size; ++pos)
arr = &activityCalendar.dayProfileTablePassive;
ret = arr_getByIndex(arr, pos, (void**)&dp);
return ret;
printf("DayId: %d\n", dp->dayId);
for (pos2 = 0; pos2 != dp->daySchedules.size; ++pos2)
ret = arr_getByIndex(&dp->daySchedules, pos2, (void**)&dpAct);
return ret;
time_print(NULL,&dpAct->startTime);
char ln[25] ={0};
hlp_getLogicalNameToString(dpAct->scriptLogicalName, ln);
printf("\tLogical name: %s",ln);
printf("\tScritp Selector : %d\n",dpAct->scriptSelector);
Below is the trace and output
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
TX: 7E A0 41 03 41 10 E4 8F E6 E6 00 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 4C 57 54 53 4D BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 82 CC 7E
RX: 7E A0 37 41 03 30 21 79 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 D6 00 07 A7 F9 7E
Return value of = 0
TX: 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 81 00 14 00 00 0D 00 00 FF 09 00 82 BD 7E
RX: 7E A0 FC 41 03 52 F9 C2 E6 E7 00 C4 01 81 00 01 01 02 02 11 01 01 0C 02 03 09 04 01 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 03 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 06 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03 02 03 09 04 09 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04 02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 05 02 03 09 04 0F 00 00 00 09 06 00 00 0A 00 64 FF 12 00 06 02 03 09 04 12 00 00 00 09 06 00 00 0A 00 64 FF 12 00 07 02 03 09 04 15 00 00 00 09 06 00 00 0A 00 64 FF 12 00 08 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 00 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 00 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 00 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 00 52 F1 7E
Updating the value...
Object Type = 20
DayId: 1
01:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
03:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
06:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
09:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
12:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
15:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
18:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
21:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
00:00:00 Logical name: 00.00.00.00.00.00 Scritp Selector : 0
TX: 7E A0 07 03 41 53 56 A2 7E
Enabled only below macro in gxignore.h
#define DLMS_IGNORE_OBJECT_POINTERS
Mohan Raj
6 years 6 months ago
Hi Mohan,
Hi Mohan,
Please, don't create a new thread from the same question. I'll continue answering in the old thread.
http://www.gurux.fi/comment/16734
Mohanraj
In reply to Hi Mohan, by Kurumi
Thanks. I will continue the discussion in other thread. Thank you so much
Mohan Raj
