  3. Gurux.dlms.client.example.java - How To Read Voltage,current Etc
gurux.dlms.client.example.java - How to read Voltage,current etc
By priyankapatil , 3 April, 2020
I am trying to use gurux.dlms.client.example.java for reading DLMS electric meter.
I am running jar in command prompt using below command:
gurux.dlms.client.example.java\target>java -jar gurux.dlms.client.example.java-0.0.1-SNAPSHOT
.jar -S com3 -c 10 -s 1 -a none
below is trace.txt :
TX: 19:50:38.653 7E A0 07 03 15 93 CD D0 7E
RX: 19:50:38.709 7E A0 20 15 03 73 BC 7D 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
TX: 19:50:38.715 7E A0 2B 03 15 10 39 7E E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
TX: 19:51:38.720 7E A0 2B 03 15 10 39 7E E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
TX: 19:52:38.723 7E A0 2B 03 15 10 39 7E E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
TX: 19:53:38.724 7E A0 2B 03 15 10 39 7E E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
I have received response for first command: 7E A0 07 03 15 93 CD D0 7E
But after that getting error: Data send failed. Try to resend 1/3
Do I need to pass any other parameter?
Please help.
Thanks in advance.
priyankapatil
6 years 7 months ago
Later I tried by updating
Later I tried by updating parameters like (-c 16)
-S com3 -c 16 -s 1 -a none
with this I got responses from meter.
But I need data like Voltage, current etc.
How can I get that ?
Please guide.
Also I m getting this error
gurux.dlms.GXDLMSException: Access Error : Device reports Read-Write denied.
Am I doing anything wrong?
TX: 20:25:46.134 7E A0 07 03 21 93 0F 01 7E
RX: 20:25:46.190 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
data is --- [[B@2280cdac
TX: 20:25:46.195 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 20:25:46.313 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
TX: 20:25:46.318 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 20:25:47.005 7E AA 09 21 03 52 60 92 E6 E7 00 C4 01 C1 00 01 0A 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 01 11 00 09 06 01 00 00 00 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 A0 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 02 0F 05 03 00 02 02 0F 06 03 00 02 04 12 00 17 11 67 16 7E
TX: 20:25:47.007 7E A0 07 03 21 51 11 E4 7E
RX: 20:25:47.177 7E A0 7A 21 03 54 76 C4 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 80 52 7E
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.0.255 Ch. 0 Current association
TX: 20:25:47.284 7E A0 19 03 21 74 5D FF E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 20:25:47.972 7E AA 09 21 03 76 46 F5 E6 E7 00 C4 01 C1 00 01 0A 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 01 11 00 09 06 01 00 00 00 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 A0 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 02 0F 05 03 00 02 02 0F 06 03 00 02 04 12 00 17 11 67 16 7E
TX: 20:25:47.973 7E A0 07 03 21 91 1D 22 7E
RX: 20:25:48.138 7E A0 7A 21 03 78 18 2F 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 80 52 7E
Index: 2 Value: 0.0.40.0.0.255 Ch. 0 Current association, 0.0.40.0.1.255 Ch. 0 Association #1, 1.0.0.0.6.255 Ch. 0 Electricity ID #7, 1.0.96.160.0.255 Man. specific, 1.0.0.0.1.255 Ch. 0 Electricity ID #2, 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number, 0.0.42.0.0.255 Ch. 0 COSEM Logical device name, 0.0.1.0.0.255 Ch. 0 Clock object #1, 0.0.22.0.0.255 Ch. 0 IEC HDLC setup, 0.0.96.5.4.255 Ch. 0 Internal operating status (status word #4)
TX: 20:25:48.141 7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 03 00 49 4A 7E
RX: 20:25:48.204 7E A0 17 21 03 9A 6F F9 E6 E7 00 C4 01 C1 00 02 02 0F 10 12 00 01 EB 3C 7E
Index: 3 Value: 16/1
TX: 20:25:48.206 7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 04 00 41 07 7E
RX: 20:25:48.270 7E A0 19 21 03 BC 19 13 E6 E7 00 C4 01 C1 00 09 07 60 85 74 05 08 01 01 E2 49 7E
Index: 4 Value: 0 0 0 5 8 1 LOGICAL_NAME
TX: 20:25:48.271 7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 05 00 99 1E 7E
RX: 20:25:48.349 7E A0 23 21 03 DE 51 C3 E6 E7 00 C4 01 C1 00 02 06 04 18 00 00 10 12 02 00 12 04 00 11 06 0F 00 09 00 20 EE 7E
Index: 5 Value: [GET] 512 1024 6 0
TX: 20:25:48.351 7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 06 00 F1 34 7E
RX: 20:25:48.416 7E A0 19 21 03 F0 71 9B E6 E7 00 C4 01 C1 00 09 07 60 85 74 05 08 02 00 03 72 7E
Index: 6 Value: 0 0 0 5 8 2 None
TX: 20:25:48.417 7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 07 00 29 2D 7E
RX: 20:25:48.472 7E A0 11 21 03 12 B5 BA E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 7 Access Error : Device reports Read-Write denied.
TX: 20:25:48.473 7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 08 00 E1 AE 7E
RX: 20:25:48.529 7E A0 12 21 03 34 4C DB E6 E7 00 C4 01 C1 00 16 02 01 23 7E
Index: 8 Value: ASSOCIATED
-------- Reading GXDLMSAssociationLogicalName 0.0.40.0.1.255 Ch. 0 Association #1
TX: 20:25:48.531 7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 02 00 2A 4F 7E
RX: 20:25:49.217 7E AA 09 21 03 56 44 D4 E6 E7 00 C4 01 C1 00 01 0A 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 01 11 00 09 06 01 00 00 00 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 A0 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 02 0F 05 03 00 02 02 0F 06 03 00 02 04 12 00 17 11 67 16 7E
TX: 20:25:49.218 7E A0 07 03 21 91 1D 22 7E
RX: 20:25:49.379 7E A0 7A 21 03 58 1A 0E 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 80 52 7E
TX: 20:25:49.381 7E A0 19 03 21 B4 51 39 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 03 00 F2 56 7E
RX: 20:25:49.444 7E A0 17 21 03 7A 61 1E E6 E7 00 C4 01 C1 00 02 02 0F 10 12 00 01 EB 3C 7E
TX: 20:25:49.445 7E A0 19 03 21 D6 45 79 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 04 00 FA 1B 7E
RX: 20:25:49.517 7E A0 19 21 03 9C 1B 32 E6 E7 00 C4 01 C1 00 09 07 60 85 74 05 08 01 01 E2 49 7E
TX: 20:25:49.518 7E A0 19 03 21 F8 39 B1 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 05 00 22 02 7E
RX: 20:25:49.596 7E A0 23 21 03 BE 57 A0 E6 E7 00 C4 01 C1 00 02 06 04 18 00 00 10 12 02 00 12 04 00 11 06 0F 00 09 00 20 EE 7E
TX: 20:25:49.597 7E A0 19 03 21 1A 25 75 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 06 00 4A 28 7E
RX: 20:25:49.661 7E A0 19 21 03 D0 73 BA E6 E7 00 C4 01 C1 00 09 07 60 85 74 05 08 02 00 03 72 7E
TX: 20:25:49.662 7E A0 19 03 21 3C 11 31 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 07 00 92 31 7E
RX: 20:25:49.716 7E A0 11 21 03 F2 BB 5D E6 E7 00 C4 01 C1 01 03 73 82 7E
TX: 20:25:49.718 7E A0 19 03 21 5E 05 71 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 08 00 5A B2 7E
RX: 20:25:49.774 7E A0 12 21 03 14 4E FA E6 E7 00 C4 01 C1 00 16 02 01 23 7E
-------- Reading GXDLMSData 1.0.0.0.6.255 Ch. 0 Electricity ID #7
TX: 20:25:49.776 7E A0 19 03 21 70 79 B9 E6 E6 00 C0 01 C1 00 01 01 00 00 00 06 FF 02 00 59 E6 7E
RX: 20:25:49.855 7E A0 19 21 03 36 4B 38 E6 E7 00 C4 01 C1 00 09 07 45 53 4C 2D 30 30 32 8F 8F 7E
Index: 2 Value: ESL-002
-------- Reading GXDLMSData 1.0.96.160.0.255 Man. specific
TX: 20:25:49.858 7E A0 19 03 21 92 65 7D E6 E6 00 C0 01 C1 00 01 01 00 60 A0 00 FF 02 00 B6 C0 7E
RX: 20:25:50.135 7E A0 BB 21 03 58 78 29 E6 E7 00 C4 01 C1 00 01 0D 02 02 09 06 01 00 01 08 00 FF 12 00 86 02 02 09 06 01 00 02 08 00 FF 12 00 85 02 02 09 06 01 00 81 08 00 FF 12 00 82 02 02 09 06 01 00 82 08 00 FF 12 00 81 02 02 09 06 01 00 05 08 00 FF 12 00 96 02 02 09 06 01 00 06 08 00 FF 12 00 98 02 02 09 06 01 00 07 08 00 FF 12 00 97 02 02 09 06 01 00 08 08 00 FF 12 00 95 02 02 09 06 01 00 09 08 00 FF 12 00 A1 02 02 09 06 01 00 0A 08 00 FF 12 00 A5 02 02 09 06 01 00 5E 5B 01 FF 12 00 E3 02 02 09 06 01 00 5E 5B 02 FF 12 00 E4 02 02 09 06 01 00 10 08 00 FF 12 00 F0 9A 54 7E
Index: 2 Value: [[B@6ea6d14e, 134], [[B@6ad5c04e, 133], [[B@6833ce2c, 130], [[B@725bef66, 129], [[B@2aaf7cc2, 150], [[B@6e3c1e69, 152], [[B@1888ff2c, 151], [[B@35851384, 149], [[B@649d209a, 161], [[B@6adca536, 165], [[B@357246de, 227], [[B@28f67ac7, 228], [[B@256216b3, 240]
-------- Reading GXDLMSData 1.0.0.0.1.255 Ch. 0 Electricity ID #2
TX: 20:25:50.137 7E A0 19 03 21 B4 51 39 E6 E6 00 C0 01 C1 00 01 01 00 00 00 01 FF 02 00 78 B1 7E
RX: 20:25:50.213 7E A0 19 21 03 7A 23 B0 E6 E7 00 C4 01 C1 00 09 07 4D 32 58 37 47 30 33 F2 49 7E
Index: 2 Value: M2X7G03
-------- Reading GXDLMSData 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number
TX: 20:25:50.214 7E A0 19 03 21 D6 45 79 E6 E6 00 C0 01 C1 00 01 00 00 60 01 00 FF 02 00 89 A0 7E
RX: 20:25:50.290 7E A0 1A 21 03 9C D6 17 E6 E7 00 C4 01 C1 00 09 08 58 44 35 30 30 38 38 31 AA BA 7E
Index: 2 Value: XD500881
-------- Reading GXDLMSData 0.0.42.0.0.255 Ch. 0 COSEM Logical device name
TX: 20:25:50.314 7E A0 19 03 21 F8 39 B1 E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 02 00 12 80 7E
RX: 20:25:50.394 7E A0 1B 21 03 BE 7D 09 E6 E7 00 C4 01 C1 00 09 09 45 48 4C 45 33 44 78 78 78 18 26 7E
Index: 2 Value: EHLE3Dxxx
-------- Reading GXDLMSClock 0.0.1.0.0.255 Ch. 0 Clock object #1
TX: 20:25:50.395 7E A0 19 03 21 1A 25 75 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
RX: 20:25:50.503 7E A0 1E 21 03 D0 52 ED E6 E7 00 C4 01 C1 00 09 0C 07 E4 04 04 06 14 1A 3A FF 80 00 00 D0 93 7E
Index: 2 Value: 04/04/20, 8:26:58 pm
TX: 20:25:50.514 7E A0 19 03 21 3C 11 31 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 03 00 B8 03 7E
RX: 20:25:50.574 7E A0 11 21 03 F2 BB 5D E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 3 Access Error : Device reports Read-Write denied.
TX: 20:25:50.580 7E A0 19 03 21 5E 05 71 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 04 00 B0 4E 7E
RX: 20:25:50.640 7E A0 11 21 03 14 83 DF E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 4 Access Error : Device reports Read-Write denied.
TX: 20:25:50.642 7E A0 19 03 21 70 79 B9 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 05 00 68 57 7E
RX: 20:25:50.702 7E A0 11 21 03 36 93 DD E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 5 Access Error : Device reports Read-Write denied.
TX: 20:25:50.703 7E A0 19 03 21 92 65 7D E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 06 00 00 7D 7E
RX: 20:25:50.763 7E A0 11 21 03 58 EB 57 E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 6 Access Error : Device reports Read-Write denied.
TX: 20:25:50.763 7E A0 19 03 21 B4 51 39 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 07 00 D8 64 7E
RX: 20:25:50.824 7E A0 11 21 03 7A FB 55 E6 E7 00 C4 01 C1 01 03 73 82 7E
TX: 20:25:50.825 7E A0 19 03 21 D6 45 79 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 08 00 10 E7 7E
RX: 20:25:50.885 7E A0 11 21 03 9C C3 D7 E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 8 Access Error : Device reports Read-Write denied.
TX: 20:25:50.886 7E A0 19 03 21 F8 39 B1 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 09 00 C8 FE 7E
RX: 20:25:50.945 7E A0 11 21 03 BE D3 D5 E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 9 Access Error : Device reports Read-Write denied.
-------- Reading GXDLMSHdlcSetup 0.0.22.0.0.255 Ch. 0 IEC HDLC setup
TX: 20:25:50.946 7E A0 19 03 21 1A 25 75 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 02 00 BD 2D 7E
RX: 20:25:51.009 7E A0 12 21 03 D0 66 7A E6 E7 00 C4 01 C1 00 16 05 BE 57 7E
Index: 2 Value: Baudrate9600
TX: 20:25:51.010 7E A0 19 03 21 3C 11 31 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 03 00 65 34 7E
RX: 20:25:51.072 7E A0 12 21 03 F2 76 78 E6 E7 00 C4 01 C1 00 11 01 92 5C 7E
Index: 3 Value: 1
TX: 20:25:51.073 7E A0 19 03 21 5E 05 71 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 04 00 6D 79 7E
RX: 20:25:51.134 7E A0 12 21 03 14 4E FA E6 E7 00 C4 01 C1 00 11 01 92 5C 7E
Index: 4 Value: 1
TX: 20:25:51.136 7E A0 19 03 21 70 79 B9 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 05 00 B5 60 7E
RX: 20:25:51.199 7E A0 13 21 03 36 E5 E4 E6 E7 00 C4 01 C1 00 12 02 00 B3 82 7E
Index: 5 Value: 512
TX: 20:25:51.202 7E A0 19 03 21 92 65 7D E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 06 00 DD 4A 7E
RX: 20:25:51.264 7E A0 13 21 03 58 9D 6E E6 E7 00 C4 01 C1 00 12 02 00 B3 82 7E
Index: 6 Value: 512
TX: 20:25:51.266 7E A0 19 03 21 B4 51 39 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 07 00 05 53 7E
RX: 20:25:51.328 7E A0 13 21 03 7A 8D 6C E6 E7 00 C4 01 C1 00 12 09 F6 A2 F4 7E
Index: 7 Value: 2550
TX: 20:25:51.328 7E A0 19 03 21 D6 45 79 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 08 00 CD D0 7E
RX: 20:25:51.391 7E A0 13 21 03 9C B5 EE E6 E7 00 C4 01 C1 00 12 00 3C EC 4A 7E
Index: 8 Value: 60
TX: 20:25:51.391 7E A0 19 03 21 F8 39 B1 E6 E6 00 C0 01 C1 00 17 00 00 16 00 00 FF 09 00 15 C9 7E
RX: 20:25:51.454 7E A0 13 21 03 BE A5 EC E6 E7 00 C4 01 C1 00 12 01 00 DB A8 7E
Index: 9 Value: 256
-------- Reading GXDLMSData 0.0.96.5.4.255 Ch. 0 Internal operating status (status word #4)
TX: 20:25:51.455 7E A0 19 03 21 1A 25 75 E6 E6 00 C0 01 C1 00 01 00 00 60 05 04 FF 02 00 75 FF 7E
RX: 20:25:51.519 7E A0 11 21 03 D0 AB 5F E6 E7 00 C4 01 C1 01 03 73 82 7E
Error! Index: 2 Access Error : Device reports Read-Write denied.
TX: 20:25:51.521 7E A0 07 03 21 53 03 C7 7E
RX: 20:25:51.574 7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
Try to use GXDLMSDIrector to read your meter. It helps you understand what kind of data your meter can offer. I believe that you need to increase the authentication level from None to Low to get register data from your meter. Try parameters like this:
-S com3 -c 32 -s 1 -a Low -P Your_Meter_Password
priyankapatil
6 years 6 months ago
Thank you for your reply.
When I tried command as suggested by you, I was able to get response properly. But it is huge data.
Can I fetch only required data like Voltage, current etc without calling getAssociationView(), readScalarAndUnits() and getProfileGenricColumns().
I basically don't want to read all data. How to do that ?
Priyanka
You can modify the source code. You can also call app with parameters -o C:\association.xml -g "OBISCODE:AttributeIndex". It saves association view to the XML file and reads only wanted attribute index.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
