  3. OBIS Code To GXDLMSObject
OBIS code to GXDLMSObject
By Bhaumik , 1 April, 2020
I want to create GXDLMSObject from OBIS code.
Can you please provide an update how to create it from obis code.
6 years 7 months ago
OBIS code doesn't define always object type explicit. For this reason, you need to read this information from the meter. You can get this info when you read association view.
Bhaumik
Thanks for the update.
If I provide Object Type and OBIS code, then it is possible to create GXDLMSObject or else I have to read it through association only?
If your object type is data you can create data object like this:
GXDLMSData d = new GXDLMSData("OBIS CODE");
//Read value.
