  3. Can I Use Different Association (None/Low/High Authentication) In Single TCP/IP Connection.
Can I use different association (None/Low/High Authentication) in single TCP/IP connection.
By pradson , 25 February, 2020
Hi MIkko,
Can I write data into the meter (with high authentication) at the time of data reading (with low authentication) from the meter?
Actually, my requirement is that I want to write system time into the meter at the time when application is reading the data from the meter. I am using Low authentication for data reading and High authentication for data writing. Is this possible without disconnection of meter? I am using c++ to achieve this.
Kindly suggest me.
Thanks & Regards,
Pradson
6 years 5 months ago
Hi Pradson,
Hi Pradson,
I have to say that this depends on the meter. Some meters allow multiple connections at the same time, some only one.
I believe that you have to close the connection and start again, but you need to test this with your meter.
  • Duaneduh
  • ClaytonPap
  • sAYgntkdaTjhgpvfz
  • HenryEneno
  • ScottCab
