  3. DLMS Response Parsing
DLMS Response parsing
By Bhaumik , 19 February, 2020
Currently, I am testing meters with different interfaces (Serial/TCP/MQTT). I am using Gurux.DLMS source code for debugging.
If any Response/Event/Push data received from the meter, for parsing of that payload is there any common function available in source code?
Can you please check and provide an update.
6 years 9 months ago
GXReplyData notify = new GXReplyData();
You can use GXDLMSClient.GetData function for that.
if (!Client.GetData("RECEIVED DATA FROM THE METER", reply, notify))
if (notify.Data.Data != null)
//Handle notify.
if (!notify.IsMoreData)
