  3. Event Notification Parsing
By Bhaumik , 7 February, 2020
Gurux.Net
Event notification is received from the meter and also able to parse in XML format.
Following is the event notification data:
7EA0706103131528E6E7000FC00000010002030103020412002809060000190900FF0F021200000204120001090600002A0000FF0F021200000204120001090600005E5B12FF0F02120000091047525830303030303030313233343536091000000000000000000000200000000000E6EE7E
<HDLC len="6F" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="13" />
<PDU>
<DataNotification>
<LongInvokeIdAndPriority Value="C0000001" />
<DateTime Value="" />
<NotificationBody>
<DataValue>
<Structure Qty="03" >
<Array Qty="03" >
<Structure Qty="04" >
<UInt16 Value="0028" />
<OctetString Value="0000190900FF" />
<Int8 Value="02" />
<UInt16 Value="0000" />
</Structure>
<UInt16 Value="0001" />
<OctetString Value="00002A0000FF" />
<Int8 Value="02" />
</Structure>
<OctetString Value="00005E5B12FF" />
<Int8 Value="02" />
</Structure>
</Array>
<OctetString Value="47525830303030303030313233343536" />
<OctetString Value="00000000000000000000200000000000" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</HDLC>
Now I want to check which event is sent from the meter. For that, Is there any parsing available
in Gurux DLMS code ?
6 years 9 months ago
The event can be basically anything, but in your case meter is sending push object list as a first parameter.
This makes it possible to handle this.
You can use ParsePushObjects method to parse received data.
You can check Gurux.DLMS.Push.Listener.Example.Net for more info. Just change interface from WRAPPER to HDLC.
List<KeyValuePair<GXDLMSObject, int>> objects = client.ParsePushObjects((List<object>)tmp[0]);
Bhaumik
Thanks for the quick reply.
We have generated this event from the example server. At present we don't know in that format meter is sending the event.
I have read Event Status Word from GXDLMSDirector. In that bitstring response received, Now I want to check which event is occured. So Is there any specific parsing for events in Gurux code respective to IS15959-2.
Is OBIS code 0.0.94.91.18.255?
Bhaumik
Yes, OBIS code is 0.0.94.91
Yes, OBIS code is 0.0.94.91.18.255
We'll update bit string values and release them on Monday.
Bhaumik
Thanks for the support.
Let me know once you release it today.
Bhaumik
Any update on release?
Tests are almost finished.
We released yesterday a new version from GXDLMSDirector get it. Then there are new manufacturer settings for India standard. Update new manufacturer settings and then read the association view again.
Yo can now see possible values as bit string and checked list when you select Event Status Word 1 (ESW-1).
Bhaumik
Thank you so much for the
Thank you so much for the release.
Now able to check properly for the occurred events.
