  3. GXDLMSLimiter Class
GXDLMSLimiter Class
By utkarsh , 4 February, 2020
GXDLMSLimiter class is having monitoredValue.
private GXDLMSObject monitoredValue;
but as per blue book it should as below
monitored_value
Defines an attribute of an object to be monitored. Only attributes with simple data types are allowed.
value_definition ::= structure
class_id: long-unsigned,
logical_name: octet-string,
attribute_index: integer
which is implement through GXDLMSMonitoredValue.
Please let me know your inputs on it.
Utkarsh
6 years 9 months ago
They are the same. structure defines what object is monitored. Java is using GXDLMSObject to help programmer to avoid all DLMS specific stuff.
You can use it like this:
GXDLMSRegister r = new GXDLMSRegister("OBIS CODE");
monitoredValue = r;
MonitoredAttributeIndex = 2;
