  3. Problem Sending Compact Data With Push Setup
Problem sending Compact Data with Push Setup
By Rubent , 21 January, 2020
First of all thank you for the inconvenience it may cause.
We are trying to send / simulate a meter which sends a push setup object with a compact data with the buffer with the corresponding pdu. We simulate a secure send using GXDLMSSecureNotify. The problem is that the structure that generates us is the following:
<WRAPPER len="263" >
<TargetAddress Value="1" />
<SourceAddress Value="102" />
<PDU>
<DataNotification>
<LongInvokeIdAndPriority Value="3221225473" />
<DateTime Value="" />
<NotificationBody>
<DataValue>
<Structure Qty="1" >
<OctetString Value="0A5E26F8E9204D50524E4349475041594E494946594D4B414E5A4E53424C4249484F414847580001045E26F954000007F330000E004D001A0041003F004200130040000E003A004E001B00480011000E000B00040045003D0006002E005B00380035005D0011000A0002005F0023004C0010000900310025005200160018004000090002002A0023004B004400080001005D0000000000151E0C40241E0C00241E0B80231E0900221E0900221DEBE0241DEBA0241DEB20231D9540221D9520221D8F40241D8F00241D8E8023038BC022038BC0220385A024038580240384E0230004005F00028022000280220000004F00000071" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</WRAPPER>
This does not correspond to what the Blue Book says about the compact data object. Since the buffer attribute should be an OctetString and not be within a structure.
GURUX RESPONSE
<DataValue>
<OctetString Value="(PDU DATA)" />
</Structure>
</DataValue>
BLUE BOOK (Class_id = 62)
Attribute description
compact_buffer: Contains the values of the attributes captured as an octet-string.
When the data captured is of type octet-string, bit-string, visible-string, utf8-string or array the length is also included here.
My question is: Is there a way to prevent it from going inside a structure? Is it a bug?
Thank you very much in advance for the help and the response.
Rubent Delgado
Rubent
6 years 10 months ago
Gurux Translator Response
I believe that you are using C#? Can you show how you are adding capture objects before sending data?
Rubent
Of course Mikko. This is an
Of course Mikko. This is an example:
var compactData = new GXDLMSCompactData(GasEchoObisCodes.CompactDataPs10)
Version = 1,
CaptureMethod = CaptureMethod.Implicit,
CaptureObjects =
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSData(GasEchoObisCodes.UnixTime),
new GXDLMSCaptureObject(2, 0)),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSData(GasEchoObisCodes.Mprn),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSDisconnectControl(GasEchoObisCodes.OutputControlState),
new GXDLMSCaptureObject(3, 0)),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSGSMDiagnostic(GasEchoObisCodes.SignalQuality),
new GXDLMSCaptureObject(6, 3)),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSData(GasEchoObisCodes.UnixTimeStartOfGasDay),
new GXDLMSCaptureObject(2, 1)),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSRegister(GasEchoObisCodes.TotalRecordedVolume),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSRegister(GasEchoObisCodes.RemainingBatteryCapacity),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSProfileGeneric(GasEchoObisCodes.LoadSurveyProfile),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSProfileGeneric(GasEchoObisCodes.GasEchoEventsProfile),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSData(GasEchoObisCodes.EventLogPriorId),
new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(new GXDLMSData(GasEchoObisCodes.EventLogLastId),
6 years 9 months ago
I'm sorry that it takes so long. The data is correct.
You are sending compact data in the data notification message and for this reason, it's inside of the structure. I changed your data here so it's easier to read.
Here we have two objects in compact data:
GXDLMSCompactData compactData = new GXDLMSCompactData();
compactData.CaptureObjects.Add(new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(clock, new GXDLMSCaptureObject(1, 0)));
compactData.CaptureObjects.Add(new GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(clock, new GXDLMSCaptureObject(2, 0)));
p.PushObjectList.Add(new KeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(compactData, new GXDLMSCaptureObject(3, 0)));
p.PushObjectList.Add(new KeyValuePair<GXDLMSObject, GXDLMSCaptureObject>(compactData, new GXDLMSCaptureObject(2, 0)));
In Push message we are sending attributes 3 and 2.
Generated data is here:
http://www.gurux.fi/GuruxDLMSTranslator?translate=00010001001000440FC00…
I hope this helps you.
