  3. Reading Object Using High Security and Ciphered
Reading object using high security and ciphered
By Mohanraj , 13 January, 2020
I would like to read meter which is encrypted with below settings
Security
1.Security : GMAC
2.System title : ABCDEFGH
3.Clock Cipher Key : ABC1234567890ABC
Authentication Key : ABC1234567890ABC
Read Automatically
Invocation Counter : 0
Frame Counter LN : 0.0.43.1.2.255
How to to do using ANSI C client connection. DLMS Client application does not take any argument related to these pramater. please help.
Mohanraj
6 years 8 months ago
Hi Mohanraj,
Hi Mohanraj,
con.settings.authentication = DLMS_AUTHENTICATION_HIGH_GMAC;
bb_clear(&con.settings.cipher.systemTitle);
bb_addHexString(&con.settings.cipher.systemTitle, "ABCDEFGH");
bb_clear(&con.settings.cipher.blockCipherKey);
bb_addHexString(&con.settings.cipher.blockCipherKey, "ABC1234567890ABC");
bb_clear(&con.settings.cipher.authenticationKey);
bb_addHexString(&con.settings.cipher.authenticationKey, "ABC1234567890ABC");
Mohanraj
In reply to Hi Mohanraj, by Kurumi
followed your instruction.
Trace from DLMSDirector
20:59:36 Send SNRM request.
20:59:37
20:59:37 Send AARQ request.
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
20:59:37
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
20:59:37
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 80 08 D9 4A AC 96 7E
20:59:37 Disconnect request
20:59:37
20:59:37 Send SNRM request.
TX: 7E A0 07 03 41 93 5A 64 7E
20:59:38
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
20:59:38 Send AARQ request.
TX: 7E A0 53 03 41 10 33 75 E6 E6 00 60 45 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 17 04 15 21 13 20 80 08 D9 4B 22 EA 95 92 31 90 01 26 04 43 5D 19 43 2E EC 96 7E
20:59:38
RX: 7E A0 4A 41 03 30 EB A8 E6 E7 00 61 3C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 4C 4E 54 39 30 38 33 34 BE 17 04 15 28 13 20 00 02 34 C9 48 A1 00 CF C0 D9 68 6E 3E DD A6 A2 E9 5C 93 32 7E
My Code
cl_init(&con.settings,1,16,1,DLMS_AUTHENTICATION_HIGH_LOW,"lnt1",DLMS_INTERFACE_TYPE_HDLC);
/*High authentication*/
FACE_TYPE_HDLC);
con.settings.cipher.security = DLMS_SECURITY_ENCRYPTION;
con.settings.priority = DLMS_PRIORITY_HIGH;
con.settings.serviceClass = DLMS_SERVICE_CLASS_CONFIRMED;
con.settings.useLogicalNameReferencing = 0;
bb_addString(&con.settings.cipher.systemTitle,"ABCDEFGH");
bb_addString(&con.settings.cipher.blockCipherKey,"1234567890123456");
bb_addString(&con.settings.cipher.authenticationKey,"1234567890123456");
ret = com_initializeConnection(&con);
Trace from my code
TX: 7E A0 4E 03 21 10 48 58 60 43 A1 09 06 07 60 85 74 05 08 01 04 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 09 04 07 21 05 20 00 00 00 00 DE 32 7E
DLMSDirector sends release request at the beginning after connect. But my code does not send and it is struck.
what is the change required.
Please help.
Mohanraj
Hi Mohanraj,
Hi Mohanraj,
We'll update the client example today so it'll read the invocation counter.
Mohanraj
once client code gets updated please provide some inputs what are all the changes and in which file.
Mohanraj
Hi Mohanraj,
Hi Mohanraj,
Get the latest version. There are two new command line parameters.
-C and -v
You can try with those:
-C AuthenticationEncryption -v 0.0.43.1.0.255
The logical name of frame counter might be something else.
  • avadhesh.p
  • Peter Mudenda
  • Sudhanshu Yadav
  • Shivakumar
  • Spawin
