  3. Reading Events Registers (counters and Time-stamps)
Reading Events registers (counters and time-stamps)
By dwnmastrodomenico , 28 November, 2019
Hi Everyone. I want to know, if someone can help me to know how I can read the event registers from Itron meters. I have the Obis Code from this. This corresponds to group C, D, and E of the obis code for events that I try to read:
C.2.0 Event parameters change - counter
C.2.1 Event parameters change - timestamp
C.51.1 Event terminal cover opened - counter
C.51.2 Event terminal cover opened - timestamp
C.51.3 Event main cover opened - counter
C.51.4 Event main cover opened - timestamp
C.51.5 Event magnetic field detection start - counter
C.51.6 Event magnetic field detection start - timestamp
C.51.7 Event reverse power flow - counter
C.51.8 Event reverse power flow - timestamp
C.7.0 Event power down - counter
C.7.10 Event power down - timestamp
C.51.13 Event power up - counter
C.51.14 Event power up – timestamp
C.51.15 Event RTC (Real Time Clock) set - counter
C.51.16 Event RTC (Real Time Clock) set - timestamp
But Gurux Library don't read Letters how part of the Obis Code.Can someone help me please to identify which is the value equivalent to C => C.2.0 = Event parameters change - counter.
6 years 12 months ago
Some meter manufacturers are using IEC 62056-21OBIS codes that you can map to DLMS directly. I believe that is not the case with your meter.
The best way to solve this is to ask this from the meter vendor.
If you don't get the answer, you can read the meter with GXDLMSDirector and map codes by your self.
