  3. Application Association Request With Authentication Level High
Application Association request with authentication level high
By Bhaumik , 7 November, 2019
Gurux.Serial
I trying to connect meter (IS15959) with the authentication level as high.
Using GXDLMSDirector I can connect meter properly. But when I am trying from our test application it is not able to connect and gives the following response :
7EA00F61037410D7E6E700D8010683377E
Can you please check and revert back asap.
I have set all required parameters to connect the meter with authentication high.
Do I need to set any other configuration?
6 years 10 months ago
Can you post all the messages? One of your settings is wrong.
