  3. Serial Port Reading Code
By mkizilarslan , 5 November, 2019
Gurux.Serial
I want to read the Iskraemeco meter. I will use c # language and serial port for this.
I'll just read the clock and active energy value. OBIS Code(clock=0-0:1.0.0 and Active energy= 1-0:1.8.0)
The codes at https://github.com/Gurux/Gurux.Serial came very mixed.
Is it possible to add a simple code that will read the two parameters I wrote?
Thank you.
Meter Info
password: 12345678
physical address:17
logical adress:1
client adress:1
6 years 8 months ago
DLMS is a very complicated protocol. You are just checking serial port connection.
You should check Gurux.DLMS.Net
https://github.com/Gurux/Gurux.DLMS.net
Check the client example. It makes the connection and reads all the data from the meter.
You should download GXDLMSDirector and read your meter with that. I believe it helps you to get started.
  • OskoNadyLoold
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
