  3. Client.ParseUAResponse What Parsing
client.ParseUAResponse what parsing
By IgorOm , 18 February, 2019
Good day!
I am new to DLMS. Help me please.
I formed the SNRM using the method
var data = client.SNRMRequest ();
And received the answer reply.
Further I send the answer from the metering device to the method
client.ParseUAResponse (new GXByteBuffer (reply));
An exception occurs in this place. I realized that I need to send an array without the HDLC frame header to the client.ParseUAResponse () function. How to implement the analysis?
IgorOm
7 years 5 months ago
I Solved the problem:
client.GetData()
IgorOm
How to analyze the answer
If meter returns error exception is thrown. Otherwise, all parameters are updated automatically to the client. All possible responses are defined on DLMS standard.
IgorOm
Thanks for the answer.
I need to get the data types that the counter returned, like OCTET_STRING LENGTH = 6: 00 00 80 03 00 FF. But I do not know how to do it in Gurux.dlms for c#
There is a client example. It reads all the values from the meter. I believe that you should check that.
You should check GXDLMSDirector to get an idea from all the objects on the meter.
IgorOm
Thank you!
Thank you!
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
