  3. Gurux For Raspberry
Gurux for Raspberry
By DARCARPER , 9 January, 2019
I have a Raspberry, want to install Gurux but don't understand how to do it.
you can help me?
7 years 10 months ago
Gurux for Raspberry
GXDLMSDirector is not work with Raspberry PI at the moment. What programming language you want to use?
DARCARPER
I'm trying with python. I can
I'm trying with python. I can send messages through an optical probe, but the meter does not answer. I guess it will be because the initial message is not correct.
I have also tried to install GXDLMSDirector in Java, but it is impossible
Gurux for Raspberry
The best way is if you can install java to the Raspberry PI and get gurux.dlms.client.example.java from Github.
