  3. GXDLMSNotify.parsePush() Dosen't Work For All Push Message Types
GXDLMSNotify.parsePush() dosen't work for all push message types
By pramodahanya , 18 December, 2018
We have a problem while parsing the push Interval_1(0.1.25.9.0.255) message. The error we get is "[B cannot be cast to [Ljava.lang.Object;". On debugging we identified that the ordering of the objects is important. The method GXDLMSNotify.parsePush(final Object[] data) expects the first object in the data to be an ObjectArray(data[0]) but in our case, for Push Interval_1 message from the meter it is a byte array and here the class cast exception is thrown. The parsing is working fine for installation case.
Below are the messages received from the meter for OnInstallation and Interval_1 and their xml translations.
Push On Installation
00 01 00 01 00 66 00 9E 0F 00 00 00 28 0C 07 E2 0C 12 02 10 20 3A 0B FF C4 00 02 04 01 04 02 04
12 00 28 09 06 00 07 19 09 00 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 07 19 09 00 FF 0F 01 12
00 00 02 04 12 00 30 09 06 00 00 19 07 00 FF 0F 04 12 00 00 02 04 12 00 01 09 06 00 00 2A 00 00
FF 0F 02 12 00 00 09 06 00 07 19 09 00 FF 01 02 09 10 FD 8D 1A 2E 4B C6 00 00 2E 44 FD FF FE 28
2C AA 09 10 FE 80 00 00 00 00 00 00 2E 44 FD FF FE 28 2C AA 09 10 44 4E 56 31 32 33 34 35 36 37
38 39 30 31 32 33
<WRAPPER len="166" >
<TargetAddress Value="1" />
<SourceAddress Value="102" />
<PDU>
<DataNotification>
<LongInvokeIdAndPriority Value="40" />
<!--2018-12-18 16:32:58-->
<DateTime Value="07E20C120210203A0BFFC400" />
<NotificationBody>
<DataValue>
<Structure Qty="4" >
<Array Qty="4" >
<UInt16 Value="40" />
<!--0.7.25.9.0.255-->
<OctetString Value="0007190900FF" />
<Int8 Value="2" />
<UInt16 Value="0" />
</Structure>
<Int8 Value="1" />
</Structure>
<UInt16 Value="48" />
<!--0.0.25.7.0.255-->
<OctetString Value="0000190700FF" />
<Int8 Value="4" />
</Structure>
<UInt16 Value="1" />
<!--0.0.42.0.0.255-->
<OctetString Value="00002A0000FF" />
<Int8 Value="2" />
</Structure>
</Array>
<Array Qty="2" >
<OctetString Value="FD8D1A2E4BC600002E44FDFFFE282CAA" />
<OctetString Value="FE800000000000002E44FDFFFE282CAA" />
</Array>
<!--DNV1234567890123-->
<OctetString Value="444E5631323334353637383930313233" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</WRAPPER>
Push Interval 1:
00 01 00 01 00 66 00 9E 0F 00 00 00 29 0C 07 E2 0C 12 02 10 21 05 15 FF C4 00 02 03 09 06 00 01
19 09 00 FF 01 05 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01
00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00
03 09 06 01 00 02 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 02 FF 0F 02 12 00 00
01 01 02 05 09 0C 07 E2 0C 12 02 00 00 00 00 00 00 00 06 00 00 14 02 06 00 00 14 9D 06 00 00 12
2F 06 00 00 12 6B
<PDU>
<DataNotification>
<LongInvokeIdAndPriority Value="41" />
<!--2018-12-18 16:33:05-->
<DateTime Value="07E20C120210210515FFC400" />
<NotificationBody>
<DataValue>
<Structure Qty="3" >
<!--0.1.25.9.0.255-->
//For OnInstallation case this value is after the array. We also tried manually putting this value after the array but we got class cast exception for datetime(obis code-0.0.1.0.0.255)
<OctetString Value="0001190900FF" />
<Array Qty="5" >
<UInt16 Value="8" />
<!--0.0.1.0.0.255-->
<OctetString Value="0000010000FF" />
<Int8 Value="2" />
</Structure>
<UInt16 Value="3" />
<!--1.0.1.8.1.255-->
<OctetString Value="0100010801FF" />
<Int8 Value="2" />
</Structure>
<!--1.0.1.8.2.255-->
<OctetString Value="0100010802FF" />
<Int8 Value="2" />
</Structure>
<!--1.0.2.8.1.255-->
<OctetString Value="0100020801FF" />
<Int8 Value="2" />
</Structure>
<!--1.0.2.8.2.255-->
<OctetString Value="0100020802FF" />
<Int8 Value="2" />
</Structure>
</Array>
<Array Qty="1" >
<Structure Qty="5" >
<!--2018-12-18 00:00:00-->
<OctetString Value="07E20C120200000000000000" />
<UInt32 Value="5122" />
<UInt32 Value="5277" />
<UInt32 Value="4655" />
<UInt32 Value="4715" />
</Structure>
</Array>
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
</PDU>
</WRAPPER>
7 years 5 months ago
We have updated the notification example. Get the latest version.
pramodahanya
Parsing the xml to GXDLMSObject list
is there any way to parse the XML string returned by the translator into the GXDLMSObject list like how we used to get in parse push.
I have tried using the GXDLMSClient.parseObjects method but this returns invalid response. The code fails at line 1048 in GXDLMSCLient.parseLNObjects where it is checking if the buffer is starting with 0x01 but in my case, it is starting with 0x02. Below is the buffer data for the Push Interval_1 message.
02 03 09 06 00 01 19 09 00 FF 01 05 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 08 02 FF 0F 02 12 00 00 01 01 02 05 09 0C 07 E2 0C 13 03 00 00 00 3A FF C4 00 06 00 00 1D D4 06 00 00 1E C3 06 00 00 12 2F 06 00 00 12 6B
Problem with Push messages is that data can be anything. The structure of Push message is not defined. Data of your push message is below.
You can try to do following.
After you have call GetData, you can get values, but at the moment you need to create COSEM objects by your self. I'll add this to the worklist, but it's released after the New Year.
client.getData(reply, data);
printData(data.getValue());
<Structure Qty="03" >
<Array Qty="05" >
<Structure Qty="04" >
<UInt16 Value="0008" />
<Int8 Value="02" />
<UInt16 Value="0000" />
</Structure>
<UInt16 Value="0003" />
<Int8 Value="02" />
</Structure>
<Int8 Value="02" />
</Structure>
<Int8 Value="02" />
</Structure>
<Int8 Value="02" />
</Structure>
</Array>
<Array Qty="01" >
<Structure Qty="05" >
<!--12/19/2018 1:00:00 AM-->
<OctetString Value="07E20C13030000003AFFC400" />
<UInt32 Value="00001DD4" />
<UInt32 Value="00001EC3" />
<UInt32 Value="0000122F" />
<UInt32 Value="0000126B" />
</Structure>
</Array>
</Structure>
pramodahanya
Thank You Mikko
Thank You Mikko
pramodahanya
Dear Mikko, You have
Dear Mikko, You have mentioned that you will be providing a solution to create COSEM objects. If possible could you please do share a rough timeline and what COSEM objects are you planning on supporting.
Thank You
Pramod
We are testing the new version at the moment. I believe that it's released the latest next Monday.
pramodahanya
Thanks for the update Mikko
rudreshmr@gmail.com
4 years 10 months ago
Which API is used to parse
Which API is used to parse this incoming ciphered message? I am trying with java API not getting the proper response with DLMS Translator. (Here Meter is server(pushes the data, Ciphered packet), and I am writing client code which listens udp channel and need to parse). please let me know the API, so I can use to parse this DLMS object.
In reply to Which API is used to parse by rudreshmr@gmail.com
Hi rudreshmr,
Hi rudreshmr,
Please, create a new topic if you have a new question. I'll answer your question after you have created a new topic.
