  3. The System Cannot Find The Reference Specified GuruX.DLMS
The system cannot find the reference specified GuruX.DLMS
Profile picture for user Joshua SOONG
By Joshua SOONG , 6 October, 2018
I downloaded the example code Gurux.DLMS.Client.Example.VB. I am using VS 2017. When I open the project, it says "The system cannot find the reference specified GuruX.DLMS" for GuruX.DLMS. I went into "My Project" then "References". I added the "GuruX.DLMS.dll" file and yet this error persists. Can someone advice how to resolve this?
Much appreciate.
8 years 1 month ago
You need to install nuget.org for VS 2017. That will download all libraries automatically for you.
Joshua SOONG
8 years 1 month ago
In reply to The system cannot find the reference specified GuruX.DLMS by Kurumi
It is the same problem. I downloaded the nuget.org version 4.7.1. When I run the example client vb program, it is the same error message.
How can I specifically solve this?
Thanks in advance.
8 years ago
Do you have the latest version from the source code? I just try and it works without problems.
You can try this:
Select project file. and press right mouse button. Select "Manage Nuget Packages.." from the pop-up menu. Update all references.
