  3. ELSTER CONNECTIVITY AS3000/ AS3500 & AM300
By ajesh.jacob , 26 September, 2018
Dear All
I am fresher over here and interested in DLMS and AMR.
In my hand I am having the following things.
Elster AS3000 Three phase meter
Elster AM300 module as ethernet gateway
Gurux DLMS
I would like to know how can we connect and communicate the meter with the HES (gurux DLMS), a few queries are attached here with screenshoot.
Gateway
PRODUCT: ELSTER AS 3000 THREE PHASE
COMMUNICATION MODULE : AM300
PORT : ETHERNET COMMUNICATION.
DESCRIPTION AS 3000 ENERGY METER AM 300 COMMUNICATION MODULE
SERIAL NUMBER XXXXXXXXXXXXXXXXX
MAC NUMBER 000011112222AAA
I am trying to access the meter by using the following application Gurux GXDLMSDirector.
Kindly advice the data for configuring and accessing the meter.
Access password.
Host Name: IP address of module/ the gateway page name.
Port to call the AM300
Logical Server number.
Network ID:
Physical device address :
ASCII:
7 years 10 months ago
ELSTER AS3000/ AS3500 & AM300
Can you communicate with your meter using Authentication None and optical head? If you can, you can get TCP/IP settings from there. Password, etc you should ask from the meter vendor.
ajesh.jacob
yes we can communicate via a
yes we can communicate via a software package to modify the meter parameters and extract the data or readings using the optical probe and this package.
Did you ever accessed any elster meter with Gurux DLMS software?
Yes, we are reading Elster meters. If you can access the meter, you can get the right settings from the meter. Some of the parameters (like the password) are usually changed. TCP/IP address depends from your network.
ajesh.jacob
Communication Module
Which communication module you are using for communicating Elster AS3000 to the system via ethernet, is it AM300 or something else.
I am having the access to meter, with optical probe, software to configure the AS3000 meter.
ajesh.jacob
Dear
Again do you have HES.
I'm sorry but I can't remember the model of the communication module. You can use GXDLMSDirector to read your meter or make your own HES. We don't have ready HES to you because our clients usually have different needs.
  • rcprociG
  • helloworld
  • Kak_nvKr
  • Geraldtup
  • Kak_jhKr
