By ajit.singh@far…, 31 August, 2018 Forums Gurux.DLMS Hi, I am trying to read individual OBIS code with below given command but it is getting failed with segmentation fault. ./gurux.dlms.client.bin -S /dev/ttyUSB0:9600:8None1 -g "1.0.9.8.7.255:2" -a "Low" -P "ABCD0001" -c 32 -s 16640 Also when I try to read all data it is working fine. Can you help me to rectify where i am going wrong? Awaiting for your response. BR, Ajit Reading Individual OBIS code issue. Hi, I believe that this is CPP version? First, make sure that this obis code is right and it on the meter. BR, Mikko Hi Mikko, Hi Mikko, Thank you very much for your promt reply. BR, Ajit Log in or register to post comments
Ajit
