I´m having some problem setting special days. I have a tool that´s not using Gurux, setting the special day from there succeeds, setting the special day with Gurux fails. The data sent from the tool looks like this:
Are you looking at this, if it´s a bug in Gurux? We are using version 8.5.1711.1701 of Gurux.DLMS.Net. I can´t see that you have made any changes regarding SpecialDays since then. It´s quite urgent for us to get pass this problem.
Problem with Special Days
Are you using C#, ANSI C, ANSI C++ or Java version?
BR,¨
We are using C# /Helena
We are using C#
/Helena
GXDLMSSpecialDaysTable
Are using GXDLMSSpecialDaysTable.Insert method to add this entry?
Or are you generating this by yourself?
Yes, we are using Insert.
/Helena
Hello
Hello
Regards
Helena
We are checking this. I'll give more information today.
This is fixed in Version 8.5.1803.0401. Get the latest version.
Thank you, now it works :-)
Regards
Helena
Hi Helena
Thanks for this info. Have a nice and relaxing Easter.
