By hassin Ayaz, 24 December, 2017 Forums Gurux.Net Hello , I have a problem regarding server(meter) addressing in the raw HDLC frame the destination address should be 0x00 0x02 0x00 0x03 & the source address should be 0x03 in order to do the the above what should be the ServerAddress in the Gurux.DLMS.METER.Listener.Net example code ? here is the code snippet GXDLMSClient client = new GXDLMSClient(); client.UseLogicalNameReferencing = true; client.Authentication = Enums.Authentication.None; client.Password = null; client.InterfaceType = Enums.InterfaceType.HDLC; client.ClientAddress = 0x01; //this is okay client.ServerAddress = 0x0001; //I am stuck here Thank you Addressing Hi, client.ServerAddress = 0x4001; BR, Mikko Addressing Hi , Thanks a Lot it has worked BR Hassin Ayaz Addressing Dear Mr Kurumi I want to understand how gurux calculates logical address of the server address For example if i put the following values at GXDLMSDirector Software client address = 1= 0x01 logical server = 1= 0x01 physical server = 10 = 0x10 Then According to DLMS address theory , for 2 byte address size in the HDLC frame client address should be 0x03 locical address should be 0x02 physical address should be 0x21 the generated hdlc snrm frame by GXDLMSDirector software is 0x7E 0xA0 0x08 0x02 0x21 0x03 0x93 0x86 0xC1 0x7E this is okay ,it matches with the theory but in the C# client code the output frame does not match here is my code snippet ------------------------------------------------ client.ServerAddressSize = 2; client.ClientAddress = 0x01; client.ServerAddress = 0x0110; ----------------------------------------------- and here is the output hdlc snrm frame ---------------------------------------------- Send SNRM request.0x7E 0xA0 0x08 0x04 0x21 0x03 0x93 0x1C 0x8A 0x7E ---------------------------------------------- So does the client code calculated address differenlty than the GX software ? It would be great if you reply Thanks A Lot & Best regards Hassin AYaz Addressing Dear Mr Kurumi i have an update . using server.address = 0x4010 , 4 byte server address was generated and meter accepted that too Thank you & best regards hassin ayaz Hi, Hi, I have described how counting address here: http://www.gurux.fi/dlmsAddress You can count server address GXLMDSClient.GetServerAddress(logical, physical); BR, Mikko Addressing Dear Mr Kurumi , thanks a lot for the explanation . Addressing Hello Mr Kurumi i am trying to connect to a DCU using GXDLMSDirector Desktop Software The DCU communicates with its own software and the SNRM packet sent by its software is 7E A0 21 00 02 22 23 03 93 .... what should be the "Physical Server" Value in the GxDirector software to generate the same Physical address raw packet 0x22 0x23 ? thanks in advance Addressing Hi, Client address: 1 Logical Server address: 1 Physical server address: 2193 (0x891) BR, Mikko Addressing Thanks A Lot Mr Kurumi . server address has matched Log in or register to post comments
Addressing
Addressing
Hi ,
Thanks a Lot
it has worked
BR
Hassin Ayaz
Addressing
Dear Mr Kurumi
in the HDLC frame
Hassin AYaz
Addressing
Dear Mr Kurumi
hassin ayaz
Addressing
Dear Mr Kurumi ,
Addressing
Hello Mr Kurumi
thanks in advance
Addressing
Client address: 1
Addressing
