By Sauto, 15 December, 2017 Forums General discussion Hi, How to know how many pulses/KWh a meter of type SL7000 761 will generate. The CT ratio is 2500/1 A and VT ratio is 6.6KV/110V. Using the software I read the configuration and settings of the meter but could't find the number of pulses per KWh. Thanks, SL7000 761 Number of Pulses Hi, As far as I know, no meter is showing this in COSEM objects. You must find out this information from the documentation of the meter. BR, Mikko Log in or register to post comments
