By ykhristo, 27 March, 2017 Forums Gurux.DLMS Dear sir, is it possible to retrieve multiple attributes (e.g. entries in use, capture objects, and data buffer of a profile generic) of a certain object in a single order using Gurux C++? best regards. Retrieving multiple attributes at once Hi, First you must check is your meter supporting Multiple references or Access services. http://www.gurux.fi/Gurux.DLMS.Conformance If your meter is supporting Multiple references you can use ReadList method. Access functionality is not yet added to C++ version. BR, Mikko Thank you so much sir. Thank you so much sir. Log in or register to post comments
