Finally i could run the program, I'm working with the serial port connection. Now, I want read something specific, like Voltage in phase 1.
Is that posible?
The program get all available objects from the meter, but i dont want to read all data from this, because this requires a lot of time. I need just maybe a couple data from the meter, something specific, according to OBIS code.
Can i do that?
Yes, you can do it. You need to save information from read registers example file. If you are using Logical name referencing you save OBIS code and if Short name referencing you save Short Name.
Then you initialize connection using SNRM and AARQ messages. After that you can read just those values what you need.
DLMS.Client.Example
You did not say are you using TCP/IP or serial port connectio, but this will work for TCP/IP.
/h=[IP Address of the meter] /p=[port number] /m=[Manufacturer, example lgz]
DLMS.Client.Example
Is that posible?
Thanks.
DLMS.Client.Example
Hi Paolo,
Example reads association view. It describes all objects what your meter can offer.
After that example reads all data from the meter.
You can see read data on the command line.
DLMS.Client.Example
Hello kurumi,
Can i do that?
Thanks a lot.
DLMS.Client.Example
