By orim, 3 November, 2016 Forums Gurux.DLMS Hi! I originally sent this as an e-mail but I thought it might be better to share it here. I got an exception while trying to write the CapturePeriod attribute, so I changed the data type in accordance to the Blue Book; from Int8 to UInt32. I have created a pull request here in case you're interested: https://github.com/Gurux/Gurux.DLMS.Net/pull/2 Works good for me but I haven't run any tests. Are there any I should run before creating a pull request? *Bump* Anything new on this matter? I think it still may be an issue, at least for me (though I have modified my code so that it works). CapturePeriod data type fix Hi, In my mind this is fixed. I'll check and let you know. BR, Mikko CapturePeriod data type fix Hi, This is fixed. I notes that there is no credits.md. I added that and updated your name to it. BR, Mikko CapturePeriod data type fix Oh, thanks! :) I didn't notice it was fixed. Great, then I can go back to building from master again! Log in or register to post comments
*Bump*
Oh, thanks! :)
