Kamstrup OMNIpower Connecting to CCC Module
3 posts / 0 new
Last post
Martin Hallberg
Hi.
I am trying to connect to the CCC Module interface but only get a error message.
I am using Gurux GXDLMS Editor version 8.0.0.20
16:02:22 Initializing serial connection.
16:02:22 04:02:22.129 Info Opening
16:02:22 04:02:22.129 Info Serial Port Settings: Port Name: COM26 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
16:02:22 04:02:22.413 Info Open
16:02:22 Send SNRM request.
7E A0 08 20 03 27 93 73 85 7E
16:02:22 04:02:22.413 Sent 7E A0 08 20 03 27 93 73 85 7E
16:02:29 Failed to receive reply from the device in given time.
16:02:29 04:02:29.414 Info Closing
16:02:29 04:02:29.432 Info Closed
vid GXDLMSDirector.GXDLMSDevice.InitializeConnection() i C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:rad 384
vid GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) i C:\Projects\GXDLMSDirector\Development\MainForm.cs:rad 929
Accrding to Kamstrup the settings for the CCC Module interface should be:
CCC Module interface Association with Low Level security (Password protected):
- Client SAP: 20 (2)
- Server SAP: 16
- Context name: Logical name addressing
- Mechanism name: Low Level security. Password default is ‘12345’
- Conformance: GET, Block transfer with GET, SET, ACTION, SELECTIVE ACCESS
2 For OMNIPOWER software revision F1 (Only) the Client SAP is 19.
Is there anyone out there that could help.
Thanks in advance.
Martin.
Martin Hallberg
The connection is now working
The connection is now working using the default settings in the tool, my fault. Bad grounding on the serial interface, was the cause.
Tbnilen
Tbnilen's picture
CCC connection to serial adapter
Hey Martin
Hope you can help me, I try to connect to CCC with a USB>Serial cabel but with no succes, could you help me the with wiring/setup to the serial adapter, I use pin 6, 5 and 2, (gnd, data out, data in).
BR Tommy
