Hi?
Thanks for your help
testing an optical sensor in the dlms.cpp version newly
The sample applications are randomly stopped(in windows)
(See Attachment)
Other case..
Then an error has occurred , such as
‘Assertion failed: 0, file c:\sites\amstechx32\dev\visual studio 2013\gurux.dlms.cpp\development\src\gxdlmsvariant.cpp, line 1408’
Testing of the serial cable is no problem
I analyze packet-analysis-tool…
I guess that client did not receive, But The meter has responded correctly
I would like to know the cause of the error..
Thank you
We made fix issue like this last week. Just to make sure. Are you using latest version?
Can you send this trace to me in text format by email? We can check this.
optical sensor issue
