Hi!!
This is Seoul, Republic of Korea
I can not write English well, please understand
I am interested in the DLMS of GURUX
I was studying DLMS, Java and Cpp version
I tested a example program you provided in java and cpp version lately
Test function is GetObjects() in example
The results were different
Java version is no problem, but cpp versions are stopped (error
code: 252)
I would like to know that why difference between the versions as same
function, same meter
Test environment are:
- Connection: Serial
- AUTHENTICATION : AUTHENTICATION_LOW
- Interface Type : HDLC
- Server/client addr: 0xA5/0x14
- UseLogicalNameReferencing: true
- Java: eclipse mars.2 4.5.2
- Cpp: visual studio 2013
Issue
Hi Seoul,
Thank you from this info. Your English is very good. We fixed this ReceiverReady issue.
Get new version from GitHub.
It works well!!
It works well!!
thank you for quick response~~
