When attempting to migrate the libraries to Linux, I run into problems as a result of the SetCommState and GetCommState functions in the libraries. These functions are called in functions that seem common to both Windows and Linux implementations.
Is there code available where these functions are written for Linux (not having HANDLE, LPDCB etc.), or should I attempt an implementation by rewriting the functions for Linux myself?
I've been following this topic and checked new App to find out the new API you mentioned.
However I did not fine it. Is it released now? Where can I find it?
All that seems to have been done is that an if statement was inserted to comment out windows code when in Linux, but no Linux code was actually added. That means it compiles, but you still can't talk via a serial link in Linux.
Will the code be updated with the required Linux functionality soon?
I'm sorry that our ANSI C++ implementation has been delayed, but our clients have kept us busy.
We have started testing phase for ANSI C++ implemtation. New version should be available during this month. We have not implemented secured connection to it yet.
Thank you for the API released.
when i run it, I face below error which causes not to run completely.
Thisgurux.dlms.client.bin: wcsrtombs.c:99: __wcsrtombs: Assertion `data.__outbuf[-1] == '\0'' failed.
Connect failed Aborted (core dumped)
While running with gdb, below errors show up:
#4 0x00007ffff729944e in __wcsrtombs (dst=dst@entry=0x0,
src=src@entry=0x7fffffffcac0, len=len@entry=0, ps=ps@entry=0x7fffffffcad0)
at wcsrtombs.c:99
#5 0x00007ffff7243281 in _IO_vfprintf_internal (s=<optimized out>,
format=<optimized out>, ap=ap@entry=0x7fffffffcf68) at vfprintf.c:1661
#6 0x00007ffff7249499 in __printf (format=<optimized out>) at printf.c:33
#7 0x0000000000404870 in main (argc=1, argv=0x7fffffffdc48)
at src/GuruxDLMSClientExample.cpp:98
In my modified source code, line 98 contains:
TRACE("Connect failed %S.\r\n", CGXDLMSConverter::GetErrorMessage(ret));
Also I don't know what is wrong to open the /dev/ttyUSB0.
Thank you for your kind help in advance.
Best regards,
Leila
Hi again,
I'm using USB to Serial port(RS485) converter.
I haven't been able to connect to the meter with this new API, while i connected to the meter by the previews API in windows. The meter is SL7000
Thank you very much for your kind help and attention.
I will check the new API.
I just realized that with the same code as below:
CGXDLMSClient cl(true, 7, 0x00020023, GXDLMS_AUTHENTICATION_LOW, "ABCDEFGH");
in previews version(without linux option), I got "7E A0 0A 00 02 00 23 07 93 FB 06 7E" as SNRM request,
while in the version (with linux option), I got "7E A0 0A 00 10 00 47 0F 93 FF FF 7E", and then did not let me to connect to the meter.
Thanks again.
Best regards,
Leila
I did this test in windows OS.
I used the lateset vesion but nothing had changed for me.
As I got an efficient result from one of the previews versions on windows, So I tested the latest one on windows OS too.
The result of running the latest one is below:
InitializeConnection
<- 16:27:33 7E A0 0A 00 10 00 47 0F 93 DF 0C 7E
SNRMRequest failed 41.
InitializeConnection failed Data send failed..
I'm using Itron SL7000 by FT232R USB UART converter (Z-TEK).
It seems that it sets the addresses inefficiently.
By your kind help, I've already been able to run the latest API on windows. It, unfortunately, is not able to run on ubuntu 14.04. An error is appeared as below:
./gurux.dlms.client.bin
Connect failed port.
It is not able to open the serial port tried to open as below codes:
if ((ret = comm.Open("/dev/ttyUSB0", false)) != 0)
and gives m_hComPort = -1
m_hComPort = open(port, O_RDWR | O_NOCTTY | O_NONBLOCK);
Please let me know how to resolve it.
Thanks for your kind attention and help in advance.
I'm working on the latest API on linux. It seems it opens the serial port by running the bin file as sudo and it sends SNRM request correctly. (7E A0 0A 00 02 00 23 21 93 18 71 7E)
In the next step, I, unfortunately, faced below problem:
#0 __memcpy_sse2_unaligned ()
at ../sysdeps/x86_64/multiarch/memcpy-sse2-unaligned.S:36
#1 0x000000000040a219 in CGXByteBuffer::AddRange(void const*, int) ()
#2 0x0000000000406eae in GXClient::Read (this=0x7fffffffe400, eop=126 '~',
reply=...) at src/GXClient.cpp:272
#3 0x0000000000407ab5 in GXClient::ReadDLMSPacket (this=0x7fffffffe400,
data=..., reply=...) at src/GXClient.cpp:660
#4 0x0000000000407e76 in GXClient::ReadDataBlock (this=0x7fffffffe400,
data=..., reply=...) at src/GXClient.cpp:700
#5 0x0000000000407617 in GXClient::InitializeConnection (this=0x7fffffffe400)
at src/GXClient.cpp:583
#6 0x0000000000404a02 in main (argc=1, argv=0x7fffffffe5f8)
at src/GuruxDLMSClientExample.cpp:111
In GXClient::Read, there are cnt=1 and bytesRead=65535
I changed the source code of GXBytebuffer::AddRange as below:
while (m_Size + count > m_Capacity)
// if(m_Size + count > m_Capacity)
//First time data is reserved only for the added data.
if (m_Capacity == 0)
m_Capacity = count;
else
m_Capacity += count + VECTOR_CAPACITY;
m_Data = (unsigned char*) realloc(m_Data, m_Capacity);
But nothing changed. Could you please help me to solve it?
Thank you from this information. It help us to find your problem. Your problems was never occurred in our test environment and we had not found it without your trace.
Your welcome and thank you for solving the problem. However I faced other problems.
In GXClient::Read function while bytesRead == 0xFFFF and errno == EAGAIN, it does not return from the function and then interrupts by reply.AddRange function.
I, also, hove to comment the part in this function which was not completed as below:
else if (cnt == 0/* || ret == */)
Thank you for the new version. I am using it but some inconvenience below described mostly occurs:
- Mostly It is not able to get a UA response from the meter. In cGXCommunication::ReadDLMSPacket() function bb variable has no data (m_Parser->GetData(bb, reply)). Finally some information appears on the terminal:
<- 10:19:29 7E A0 0A 00 02 00 23 07 93 FB 06 7E
[Inferior 1 (process 3858) exited with code 01]
I tested this version on windows and it worked well even better than before. (In previews version, While it was receiving too many data from the meter, it was interrupted by not getting on time response)
I put some delay before write() function in cGXCommunication::ReadDLMSPacket. But it did not help.
I used the latest version with both iec=false and iec=true. By iec=false, nothing has changed and the previews problem occurs.
The meter, moreover, does not work with iec=true. I always use the software with iec=false.
It seems there are some problems in timing, the time which reads serial buffer received. When I run the software step by step by gdb, it sometimes gives UA response and then occur problem in getting AARE. It, however, does not get UA response while running without interruption.
In the previews version, it sometimes gave AARE after disconnecting:
Thank you for your help and time. I added a 'do .. while' structure to ioctl() function in CGXCommunication::Read() function, then it helped to work better:
//Get bytes available.
// ret = ioctl(m_hComPort, FIONREAD, &cnt);
do{
usleep(10000);
}while(cnt == 0);
But I need a way more efficiently and securely.
I don't know if it is a mater or not, I have ran Ubuntu on a virtual machine. The software works well on windows.
Would you please help me to trace better and solve the problem?
Hello, sorry for my english, have thought to do library for php, or there is some way to use it through php, the idea is to make a system that makes a report of the consumption, and that can make a plot of correinte and tension .
Many thanks, I am currently using GXDLMSDirector and it works great with Actaris meters.
In my mind best way to go is if you create java application that collects data and save it to the DB or file. Then you have PHP app that reads data from DB.
Reason for this is that sometimes it might take long time to read or if you have multiple reads at the same time your second read will fail. Usually meters allow only one connection at the time.
Other solution is if you make reading app with java an call it from php using php exec.
DLMS / COSEM Libraries for Linux implementation
We have ANSI C version that is not open source and ANSI C++ version that is also available as open source.
You can download it here:
github.com/Gurux/GuruxDLMSLib
Client example is available here:
github.com/Gurux/GuruxDLMSLibClientExample
Server example is here:
github.com/Gurux/GuruxDLMSLibServerExample
Linux Compatibility
Hello Mikko
Kind regards
Cornel Verster
Hi Cornel,
I check this and you are right.
We will change this on next week.
We will also make makefile so it's easier to compile on
Linux.
DLMS/COSEM Serial for Linux
Are there any plans to update the Windows serial implementation of the following libraries for Linux?
https://github.com/Gurux/GuruxDLMSLibClientExample
Kind Regards
Jacques Wattel
We are making new API for ANSI C and C++ at the moment.
We will release ANSI C++ in latest next month. We have improved Linux support also.
Thank you.
You should check our new API for ANSI C++.
We have added serial port reading for Linux there.
You can read more:
http://www.gurux.fi/newAPI
Error in running DLMS/COSEM Serial for linux
at wcsrtombs.c:99
Best regards,
Leila
Hi Leila,
Are you using USB to Serial port converter or do you have serial port indide of your PC?
Can you get any data from the meter? What meter you are reading (manufacturer and model)?
set a breakpoint in gdb
Also, I added '-g' in make file to be able to set a breakpoint while running the bin file by gdb.
CFLAGS = -c -g
Thanks.
Hi again,
We have fix some issues. Get latest version from SVN and let us know if you still have probems.
What converter you are using (manufacturer and model)?
Thanks again.
Best regards,
Leila
Best Regards,
Leila
Best regards,
Leila
m_Capacity = count;
else
Thank you in advance for your kind attention.
Best regards,
Leila
We fixed this. Get latest version from GitHub.
Thanks again for your efficient and kind help.
Rest regards,
Leila
Hi Leila,
You are right. We updated wait time functionality for Linux.
Could you help me to solve it?
Best regards,
Leila
Hi Leila,
We made some changed. Try to get latest version and let me know if you still have problems.
What meter (manufacturer and model) you try to read?
Thank you for the new changes. I'll check it soon.
Best regards,
Leila
Try to set iec = true.
I would be pleased if you could help me.
Best regards,
Leila
Start InitializeConnection
(1) SNRMRequest & UAResponse
<- 12:15:38 7E A0 0A 00 02 00 23 21 93 18 71 7E
-> <- 12:15:38 7E A0 0A 00 02 00 23 21 93 18 71 7E12:15:38 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01
(2) AARQRequest & AAREResponse
<- 12:15:38 7E A0 2E 00 02 00 23 21 10 7E CB E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 99 C8 7E
AARQRequest failed 41.
1) InitializeConnection failed Data send failed..
<- 12:15:38 7E A0 0A 00 02 00 23 21 53 14 B7 7E
-> <- 12:15:38 7E A0 0A 00 02 00 23 21 53 14 B7 7E12:15:38 7E A0 3A 21 00 02 00 23 30 99 41 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 30 1D 21 34 00 07 E9 1E 7E 7E A0 0A 21 00 02 00 23 73
[Inferior 1 (process 5642) exited with code 01]
All problems are seen on Ubuntu 14.04. None of these problems appear on Windows.
I don't know how and where 'CGXDLMSClient::GetData' function fills 'CGXByteBuffer& reply' variable.
would you please help me to trace efficiently and then solve the problem?
Best regards,
Leila
I update new version. We improved client example trace and added few SN and LN flags,
but I can't get your error. It works without problems.
We will continue this tomorrow with different meter and optical strobe.
After we can dublicate your error we can fix it.
do{
usleep(10000);
}while(cnt == 0);
Best regards,
Leila
Hi Leila,
We updated new version to GitHub.
Please, let me know if you have problems.
Php is possible?
PHP
Please, add new topic if you have a new question.
