By dhanishvijayan, 12 August, 2015
Is it possible to read from SECURE premier 300 meter. Its having IEC 62053-21 standard. I am new to these protocols and doesnt know whether Gurux support this.
Please help...
IEC 62053-21 it's a little problematic standard. There are three different modes (A, B and C) and each is behavioring little bit differently.
We can make small application for you that reads your meter.
Please help to read the meter, also the spec of SECURE Premier 300 shows that it is having IS15959 indian standard(and I found somewhere in this forum that it is similar to DLMS protocol).
If your meter is supporting DLMS you do not need OBIS codes. After you have made connection to the meter you press Refresh button from the File menu and all supported OBIS codes are retreaved from the meter.
Hi any updates on Secure meter? Which component u r using other than Director,,i am using C++ component, i can help you on OBIS codes, reach me at username@yahoo.com
added manufacturer: bsm
start protocol: IEC
Media :serial
authentication: none
logical name referencing
wait time :5
client address:10
physical server :1
logical server:1
serial port :com1,300,7,e,1
We have a issue in reading Secure meter (model: premier 300).
Gurux GXDLMSDirector: 8.0.1708.1801
Manufacture settings:
Flag ID:EHL
Using logical name referencing: checked
keepinterval: 40
start protocol: DLMS
Addressing:
authenticatoin:none
client address
address(hex):10
server address
address type:Default
serial number formula
physical:1
logical:0
Device properties:
manufacture:Secure meter
Logical name referencing:checked
start protocol:DLMS
media:serial
authentical:none
password:
waittime:7
client address: 10
address type:default
physical address:1
logical address:0
settings
serial port:COM11
Optical probe head with USB (IEC62056-21)
on Tool-->Read we are only getting the following values
AssociationLogicalname
0.0.40.0.0.255 Ch 0 current association
0.0.40.0.1.255 Ch 0association #1
Data
1.0.0.0.6.255 Ch. 0 Electricity ID #7
1.0.96.160.0.255 Man. specific
1.0.0.0.1.255 Ch. 0 Electricity ID #2
0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number
0.0.42.0.0.255 Ch. 0 COSEM Logical device name
clock
0.0.1.0.0.255 ch 0 clock object #1
as per the manufacture the default authentication is ABCD001
but could not able to establish high or low level connection to the meter with the given default password.
Please, create own topic if you have question. Your client address is wrong if you try to connect with Low or High Authentication. Is this Indian meter?
have you secure meter low level password.
i got meter details (authenticaton none) but i want read load servey & insta. paramater date wise.
i think that require low level password.
"GuruxDlmsSample -S COM1 -c 16 -s 1 -a Low -P [password]" this field are nessesary
Use Default password "ABCD0001".
Secure Meter has given a wrong password in its Manual or May be a Typo.
Manual has given the password as "ABCD001" [missed one zero in between]
I am able to compile the android app but while running the app it shows erreo Program type already present: gurux.common.IGXMediaListener
Message{kind=ERROR, text=Program type already present: gurux.common.IGXMediaListener, sources=[Unknown source file], tool name=Optional.of(D8)}
Premier 300 meter
Send email to me if you are interested.
You will find my email address here:
http://www.gurux.fi/AboutUs
SECURE Premier 300 Meter reading
OBIS code for SECURE meter
I will try with a DLMS Director today, but one problem is that I dont have knowledge of OBIS codes. Can anyone share the OBIS codes
GXDLMSDirecor
bluestar meter a2000
Not able to read bluestar meter a2000 with gxdlmsdirector - has anyone read it ? -can i contact ?
What parameters you did try to use with Bluestar A2000?
Reading A2000 blue star meter
Hi kurumi,
I have the following parameters,
start protocol: IEC
Media :serial
wait time :5
client address:10
physical server :1
logical server:1
issue in reading secure premier 300 meter
Flag ID:EHL
keepinterval: 40
Addressing:
authenticatoin:none
client address
address(hex):10
server address
physical:1
logical:0
Device properties:
start protocol:DLMS
media:serial
authentical:none
password:
waittime:7
client address: 10
physical address:1
logical address:0
settings
serial port:COM11
Data
clock
GXDLMSDirector 8.0.1708.1801
Log created 16:07:01
16:07:06 Initializing serial connection.
16:07:06 Send SNRM request.
7E A0 14 03 21 93 63 E7 81 80 08 05 02 02 00 06 02 02 00 43 B0 7E
16:07:06 Received data
7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
16:07:06 Parsing UA reply.<CR><LF>81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01
16:07:06 Parsing UA reply succeeded.
16:07:06
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 60 1E DE FF FF 88 A0 7E
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
16:07:06 Parsing AARE reply succeeded.
16:07:21 Read object type AssociationLogicalName index: 2
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 01 FF 02 00 2A 4F 7E
16:07:22 Received data
7E A2 03 21 03 52 EE 14 E6 E7 00 C4 01 C1 00 01 08 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 0F 11 00 09 06 00 00 28 00 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 01 04 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 04 12 00 01 11 00 09 06 01 00 00 00 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 A0 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 03 00 02 02 0F 02 03 00 02 02 0F 03 03 00 02 02 0F 04 03 00 02 02 0F 05 03 00 02 02 0F 06 03 00 09 4A 7E
16:07:22 Read object type Data index: 2
7E A0 19 03 21 54 5F DE E6 E6 00 C0 01 C1 00 01 01 00 00 00 06 FF 02 00 59 E6 7E
7E A0 19 21 03 74 5D 59 E6 E7 00 C4 01 C1 00 09 07 45 53 4C 2D 30 30 32 8F 8F 7E
7E A0 19 03 21 76 4F DC E6 E6 00 C0 01 C1 00 01 01 00 60 A0 00 FF 02 00 B6 C0 7E
7E A0 53 21 03 96 58 57 E6 E7 00 C4 01 C1 00 01 05 02 02 09 06 01 00 01 08 00 FF 12 00 DD 02 02 09 06 01 00 05 08 00 FF 12 00 D9 02 02 09 06 01 00 08 08 00 FF 12 00 DA 02 02 09 06 01 00 09 08 00 FF 12 00 D8 02 02 09 06 01 00 94 08 00 FF 12 00 D4 56 0F 7E
7E A0 19 03 21 98 3F D2 E6 E6 00 C0 01 C1 00 01 01 00 00 00 01 FF 02 00 78 B1 7E
7E A0 19 21 03 B8 3D 55 E6 E7 00 C4 01 C1 00 09 07 4D 32 58 37 47 30 37 D6 0F 7E
7E A0 19 03 21 BA 2F D0 E6 E6 00 C0 01 C1 00 01 00 00 60 01 00 FF 02 00 89 A0 7E
16:07:23 Received data
7E A0 1A 21 03 DA E4 30 E6 E7 00 C4 01 C1 00 09 08 58 43 34 33 36 37 38 33 1A 46 7E
16:07:23 Read object type Data index: 2
7E A0 19 03 21 DC 1F D6 E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 02 00 12 80 7E
7E A0 1B 21 03 FC 6B 68 E6 E7 00 C4 01 C1 00 09 09 45 48 4C 45 33 54 78 78 78 B9 E5 7E
16:07:23 Read object type Clock index: 2
7E A0 19 03 21 FE 0F D4 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
7E A0 1E 21 03 1E 20 C2 E6 E7 00 C4 01 C1 00 09 0C 07 E1 09 05 02 10 07 11 FF 80 00 00 C1 09 7E
Regards
Anand
Hi Anandasundararaman.S,
Thank you for the quick reply
Thank you for the quick reply.
Post has been recreated in the forum.
yes its a indian manufacturer.
hello Anandasundararaman
Please anybody know the
Please anybody know the solution revert me
I have already ask you to create a new topic if you have new questions.
