By JimGod, 18 February, 2014 Modem did not responde. Modem not aswered. Before modem Detected, but not open. My phone is a Samsung Galaxy S3 i9300 Open Filed. Modem did not Responsed Hi, Are you receiving any responses from the modem? Check that your phone port is correct. Do following. 1.Click on the Windows Start button. 2.Type the following command in the search box, and then hit the Enter key. devmgmt.msc Find your phone under Serial Ports section. If your phone is not there update your phone drivers. Select properties. Select "serial port settings" -tab. Press "Advanced ..." button. Check what is your serial port number. BR, Mikko Log in or register to post comments
Do following.
devmgmt.msc
Select properties.
