By jordimassana, 26 October, 2012
I've started developing a DLMS Server ( Meter Emulator) with your c# library and I see that there is a big lack of documentation on this language. Where can I find an api doc?
Also, I've tried to add a ProfileGeneric Object to the Server and it always crash with I try to fill it with objects/XML Reading.
We are making some changes to the server side, specially Profile generic.
At this moment you must create object list by your self and it is not very easy.
I believe that you should wait for the next release from GuruxDLMS component.
We are making several improvements for Server side to make it easy to use.
Hi Mikko
I am using DLMS Director 7.0.7.1 to connect to DLMS Server.
Connect is ok
But if I try to download object list, it says "Invalid Response"
I used the example solution provided on the blog, and did not change anything.
c# API Documentation and Creating Tables on a Server
Read how to get started here:
http://www.gurux.fi/OwnDLMSDevice
Invalid Response
Hi Mikko
Connect is ok
Invalid Response
I test this and it worked on my machine. :-)
Can you send log file to us. We'll try to find reason for your problem.
