By minhvc, 27 September, 2012
I have downloaded GXSerial in Gurux Media components. When I open the GXSerial csharp Sample project it have 25 errors. Some of them :
Error 4 'Gurux.Serial.GXSerial' does not contain a definition for 'SendSync' and no extension method 'SendSync' accepting a first argument of type 'Gurux.Serial.GXSerial' could be found (are you missing a using directive or an assembly reference?) C:\Program Files\Gurux\GuruxSerial\GXSerial csharp Sample\Form1.cs 243 35 GXSerial csharp Sample
Error 5 The type or namespace name 'VariantType' does not exist in the namespace 'Gurux.Common' (are you missing an assembly reference?) C:\Program Files\Gurux\GuruxSerial\GXSerial csharp Sample\Form1.cs 243 72 GXSerial csharp Sample
Error 7 'Gurux.Serial.GXSerial' does not contain a definition for 'SendSync' and no extension method 'SendSync' accepting a first argument of type 'Gurux.Serial.GXSerial' could be found (are you missing a using directive or an assembly reference?) C:\Program Files\Gurux\GuruxSerial\GXSerial csharp Sample\Form1.cs 249 35 GXSerial csharp Sample
I have setup installed GXDLMSDirector.exe, and I found
in Gurux.Serial.dll v 7.0.0.3 Gurux.Serial.GXSerial not have SendSync method.
How can I use the sample?
I have updated the newest version and when I compile it have some errors:
Error 10 'Gurux.Common.GXCommon' is inaccessible due to its protection level ....\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 287 38 Gurux.Serial_2008
namespace Gurux.Common
internal class GXCommon {}
namespace Gurux.Serial
class ReceiveThread
public bool Receive(ReceiveParameters args)
terminator = GXCommon.GetAsByteArray(args.Eop);//this error because can not use GXCommon in Gurux.Common
we can change internal class GXCommon {} to public class GXCommon ?
When I try public class GXCommon it have errors:
Error 3 'Gurux.Common.GXCommon' does not contain a definition for 'GetAsByteArray' ...\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 46 39 Gurux.Serial_2008
Error 4 'Gurux.Common.GXCommon' does not contain a definition for 'IndexOf' ...\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 129 43 Gurux.Serial_2008
Error 5 'Gurux.Common.GXCommon' does not contain a definition for 'ByteArrayToObject' ...\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 152 36 Gurux.Serial_2008
Error 6 'Gurux.Common.GXCommon' does not contain a definition for 'TraceWriteLine' ....\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 257 55 Gurux.Serial_2008
GXSerial csharp Sample link Gurux_SVN\GXCom\Gurux.Common\Development project not Gurux_SVN\GXCom\Gurux.Communication\Development
and the newest version of Gurux.Common is Gurux_SVN\GXCom\Gurux.Communication\Development ?
Yes I have updated SVN to newest version. I have found
GetAsByteArray, IndexOf, ByteArrayToObject, TraceWriteLine functions have implementation in GXCommon of Gurux_SVN\GXCom\Gurux.Communication\Development but not in class GXCommon in Gurux_SVN\GXCom\Gurux.Common\Development.
and the GXSerial csharp Sample solution link to Gurux_SVN\GXCom\Gurux.Common\Development not Gurux_SVN\GXCom\Gurux.Communication\Development.
I opended it with GXSerial csharp Sample_2008.sln by VS2008.
At revision: 387
in folder : Gurux_SVN\GXCom\GXMedias\Gurux.Serial\GXSerial csharp Sample
I open GXSerial csharp Sample_2008.sln with VS2008
There are 3 project:
Gurux.Common_2008 project in folder \Gurux_SVN\GXCom\Gurux.Common\Development
Gurux.Serial_2008 project in folder \Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development
GXSerial csharp Sample project in and \Gurux_SVN\GXCom\GXMedias\Gurux.Serial\GXSerial csharp Sample
I rebuil all and it have 12 errors
Error 3 'Gurux.Common.GXCommon' does not contain a definition for 'GetAsByteArray' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 46 39 Gurux.Serial_2008
Error 4 'Gurux.Common.GXCommon' does not contain a definition for 'IndexOf' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 129 43 Gurux.Serial_2008
Error 5 'Gurux.Common.GXCommon' does not contain a definition for 'ByteArrayToObject' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\Shared\GXSynchronousMediaBase.cs 152 36 Gurux.Serial_2008
Error 6 'Gurux.Common.GXCommon' does not contain a definition for 'TraceWriteLine' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 257 55 Gurux.Serial_2008
Error 7 'Gurux.Common.GXCommon' does not contain a definition for 'IndexOf' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 264 26 Gurux.Serial_2008
Error 8 'Gurux.Common.GXCommon' does not contain a definition for 'GetAsByteArray' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 264 66 Gurux.Serial_2008
Error 9 'Gurux.Common.GXCommon' does not contain a definition for 'TraceWriteLine' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 282 51 Gurux.Serial_2008
Error 10 'Gurux.Common.GXCommon' does not contain a definition for 'IndexOf' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 287 47 Gurux.Serial_2008
Error 11 'Gurux.Common.GXCommon' does not contain a definition for 'GetAsByteArray' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 287 87 Gurux.Serial_2008
Error 12 'Gurux.Common.GXCommon' does not contain a definition for 'GetAsByteArray' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 1455 37 Gurux.Serial_2008
Error 13 'Gurux.Common.GXCommon' does not contain a definition for 'TraceWriteLine' E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\GXSerial.cs 1460 43 Gurux.Serial_2008
Error 14 Metadata file 'E:\Minhvc\ES_MeterReading\Gurux_SVN\GXCom\GXMedias\Gurux.Serial\Development\bin\Debug\Gurux.Serial.dll' could not be found GXSerial csharp Sample
To Mikko, can you help me?
GXSerial sample
You are using old 6.0 Serial port sample.
Download new sample here:
gurux.svn.sourceforge.net/svnroot/gurux/GXCom/GXMedias/Gurux.Serial/GXSerial csharp Sample
Download newest source codes from the Medias also.
namespace Gurux.Common(ReceiveParameters args)
class ReceiveThread
public bool Receive
GXSerial sample
This sounds strange. I can't find code that is causing problems to you.
Try to download latest version from SVN.
https://gurux.svn.sourceforge.net/svnroot/gurux/GXCom/GXMedias/Gurux.Se…
We updated SVN to newest version and it caused problems, but everything should be OK now.
At revision: 387 in folder :
At revision: 387
Problem solved.
As I said before we updated SVN to newest version and it caused problems.
Download latest source codes from Gurux Common.
Everything works after that.
