By meisam, 2 February, 2011
Hello
Gurux sounds great open-source project and I have studied about it in net and its website since last month, but I'm really confuse to use it in my project.
The first issue is the making connection to Actaris Meters and reading DLMS-COSEM protocol. I found and studied all posts and their replies but at all it's not clear that it's possible or impossible, and of course the first step is access to client-id and server-id which is not exist.
The second issue is using the component in java programming.
We do not have any Actaris meter in our office, but you can try to set Client ID to 0x10 (16) and Server ID to 0x3 (3). Those are default values.
Next week I will write a blog where I tell what those values are coming from.
There is a little problem with Actaris 7000. According Actaris there is two different versions available from 7000. If version is SL762, it is Spanish version that is implemented with the protocol IEC870-5. This vesion do not support DLMS/COSEM. There is DLMS label in the cover of the device, but that is not true. This is a little confusing. :-(
If version is SL761, DLMS/COSEM is supported and you can use our products.
We will add blog how to use DLMS component from Java later on.
We have released new version from GXDLMSDirector.
It supports Actaris. There are still something to do, because Actaris handles the data differently, but you can see that communication works and you can see the data.
We will continue adding support to Actaris and make it really readable.
hi
can any help reading actaris dlms meter
any seperate connections for optical probe or ethernet to db9 (RS232) connection
default setting like server address and client address are 16 and 3 respectively / 2 and 7 etc... i tried both not working i.e no response from metre
any suggestion on cable connection plz.......
Best way to start is download GXDLMSDirector.
Actaris settings are like this:
CGXDLMSClient cl(true, 1, CGXDLMSClient::GetServerAddress(1, 17), DLMS_AUTHENTICATION_LOW, "ABCDEFGH");
C# settings are like this:
GXDLMSClient cl = new GXDLMSClient(true, 1, GXDLMSClient.GetServerAddress(1, 17), Authentication.Low, "ABCDEFGH", InterfaceType.HDLC);
Thanks for responding
iam trying to read meter with GXDLMSDirector only i.e PC to Meter Communication with RS 232 serial communication.
But Meter not responding to optical probe as well as 2 ethernet ports provided.
is there any seperate connection required to read meter through PC using GXDLMSDirector
i already saw this posting but the settings are for Net Media.
i changed to serial and i checked with all baud rates also.....
but still no response from meter.
any connections for ethernet to rs 232 communication.............
as there are problems they are:
1. as Parameters are wrong or Manufaturer Specific.
2. and there is some problems with connection to the meter.
is there any connenction diagram for rs232 communication kindly share
Actsris EM
Happy coding,
Actaris settings
Here are settings of Actaris electricity Meter:
ServerID = (UInt16)0x0002;
ClientID = (byte)0x7;
UseLogicalNameReferencing = true;
Happy Coding,
ACTARIS
DEVICE ID : SLB761+........
OUT ADDRESS : 17
DEVICE USER : 3
Actaris settings
Actaris DLMS meter reading
hi
More info you can find from here:
http://www.gurux.fi/Gurux.DLMS.Client
thank you
regards
Sreenivas
Are you using SL7000 settings described here:
thank you
Sreenivas
You can try with 4800 8N1.
