Error reading through Director
25 posts / 0 new
Last post
Mobineers
we are trying to read EMCO make DLMS meter and we are having the following problems
At the time of downloading OBIS codes we are getting the folowing error
Profile Generic object not found.
After this some OBIS codes are downloaded.
Then we get the following error
Date / Time conversion failed. Invalid DLMS format and
Object Must Implement IConvertible.
Kurumi's picture
Re: Error reading through Director
This error is received because you have data column in your profile generic table that is not found in the device. Usually reason for this is that your device is not correctly configured.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Thanks for the prompt
Thanks for the prompt reply.
Do you mean configuring device through Director or changing configuration in meter?
How to configure the device properly?
Kurumi's picture
Sorry slow answer
For some reason I missed this. Sorry. You should configure the electricity meter.
I believe that you have received configuration program from the manufacturer.
At this point DLMSDirector is not supporting write.
We have plans to add write functionality for the data and register interfaces quite soon. Profile Generics (Tables) we are add this support later on.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Kurumi's picture
I believe that your device is not correctly configurated. After your device is working right, you should be able to read device.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Hi Mikko, I have sent you
I have sent you the screen shots of the errors received and Configuration details on your mail ID
Regards
Mobineers
Kurumi's picture
New version published
We have published new version. We have change "Profile Generic object not found." error so that it will show Logical name of the missing object.
I hope that this will help you.
If you still have problems, please select "View Log" from Tools menu and send the log file to me.
Happy Coding,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
We are using new version
We are using new version only. Also the same meter is running ok on other API provided by kalkitech.
Can we send you GSM dialup number for the meter for testing.
Mobineers
Your comments are awaited
Kurumi's picture
EMCO problem
First Í need the log file. If there are nothing strange, then we can try to make connection to your device. But first, send the log file to me.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Hi, As instructed by you we
As instructed by you we tried locating the log file
Tools--->Viw Log
We are getting error message:
The System cannot find the file specified
Regards
Kurumi's picture
Newest version
I just heard that there has been problem in SoufceForge.net.
If you click "Download Now" button, it did not download the latest version.
Latest version is 1.0.0.87.
Are you sure that you have the latest version?
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Please find Log file
Data is added to log file.
Mobineers
Hui, I have also mailed you
Hui,
I have also mailed you teh above log filealong with the erroe on your mail id
Regards
Kurumi's picture
Thanks from the log.
We will start study this tomorrow morning. You will hear us as soon as we find something.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Kurumi's picture
Problem solved
Problem solved. In Profile Generic table (OBIS: 1.0.94.91.3.255) you have added column (OBIS: 0.0.96.7.0.255) with type Register.
The problem is, that you do not have Register Interface with that OBIS code in your EM.
You have Data Interface with OBIS Code 0.0.96.7.0.255.
So you must change Profile generic column's Interface type from Register to Data.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Hi, How to change Profile
How to change Profile generic column's Interface type from Register to Data.
Please explain
Regards
Mobineers
This error is coming at the
This error is coming at the time the application is trying to capture OBIS codes from meters. How can we stop that, please help
Kurumi's picture
EM is wrong configured
Your EM is configured wrong. This has happened when you have selected columns to Profile Generic. Try to make this again or remove OBIS code 0.0.96.7.0.255 from columns.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
Hi, As instructed we have
As instructed we have deleted the OBIS code 0.0.96.7.0.255 and now we are getting other errors which I have mailed to your mail ID. Also log file is sent
Regards
Mobineers
Kurumi's picture
Info received
I have received your mail of errors and the log file. We will analyze those and you will hear from us as soon as we find out something.
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Mobineers
We are still waiting for your
We are still waiting for your response.
Kurumi's picture
EMCO Meter
We updated new version from GXDLMSDirector where we have made few bug fixes.
One bug fix probably fixed your problem.
If not, please, let me know.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
frank0317
I can't read the measuring from dlms Actaris SL7000
I need some help about that.
I am using Gurux/Cosem DLMS director to read a meter device Actaris SL7000, but the problem is that I don't get any data of the measuring, only the Logical Name.
How do I do to read the current, power, voltage, etc?.
Kurumi's picture
Actaris SL7000
You must change Authentication from None to Low.
Actaris returns only Logical name with Low authentication.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
