By gpql, 28 December, 2010
Dear all,
I'm have problem connect in iskra ME371. Port setting 300bd parity:even bit 7 stop 1.
Connect pc via converter Mbus>rs232. http://www.a2s.pl/m-bus-10-p-3150.html
Our developers will see to this as soon as possible.
In the mean while, could You kindly specify,
are using the GXDLMS/COSEM component as such, or with the UI application, GXDLMS/COSEMDirector? And if coding, what language do You use?
Also, kindly, keep checking this thread, as our developers may need yet further information of the problem.
Welcome gpql, to Gurux Forum
...and thank you for sharing the information!
Kind regards,
MerjaS
