Problem to connect a meter
8 posts / 0 new
Last post
aprinsen
I've a question about connecting with GXDLMS/COSEMDirector.
I've just download the newest version of GXDLMS/COSEMDirector. And I try connect to a meter. I have filled all required data.
When I push the connect button, I get the following message: 'Value does not fall within the expected range.'
When I look with wireshark, I can see that there is a connection established, but there is no data in the packets.
Can somebody tell what I'm doing wrong?
Thanks!
Administrator
Administrator's picture
Thanks for info.
Can you tell me the manufacturer and model of your meter?
Gurux Administrator
aprinsen
It's a Iskraemeco ME372.
It's possible to connect the meter by Meterview(Configuration tool of Iskraemeco).
Kurumi's picture
I just read data from Iskraemeco meter.
Of course it succeeded. :-)
What connection type you are using (Serial port or Network)?
Best Regards,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
aprinsen
I use a network connection. It's possible to ping the meter en read them out by Meterview from my computer.
There also something wrong with the log-files. When I push 'view log', I get the message: 'System can't find the specific file'
Maybe there is something wrong with my computer. I will try to install Gurux DLMS/COSEMDirector on a other computer.
I'll let you know the result.
Kind Regards,
aprinsen
Kurumi's picture
I believe that we found the error.
We have published new version in SourgeForge.net that should fix the problem.
Happy Coding,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
aprinsen
I've just download the newest version, and it solved all the problems.
Now I get the complete object list out of the meter.
Thank you very much, I am very happy!!
Best Regards,
aprinsen
Kurumi's picture
It's good to heard that it fixed your problem. If you have any other problems please let us know.
Happy Coding,
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
