please i have any question. what is the good procedure? i connect the sl 7000 to my pc with the ethernet cable , and install GXDLMSDirector .after , i have the configuration to do ? or i enter just the parameter ?
please excuse my english language. i try
Please, create a new thread if you have the new question.
You can connect with GXDLMSDirector. Make sure that your meter is supporting DLMS. There are two different versions from SL 7000. You can find more information here: https://www.gurux.fi/node/4013
If I remember right you need to use WRAPPER if you are using TCP/IP connection.
Try to connect with basic settings first and let me know if you have problems.
hello,
Try to connect with basic settings first and let me know if you have problems.//
please excuse me, but i don't no to use WRAPPER. please can you help me ???
please can you help me the datasheet or notice or technical documents of SL 7000 type SL761 ? i want to learn the structure of the trame, speed execution, and metrologie
Please help
I have a meter Snapshots.
With this meter how can I read data from it.
Thanks in advance.
Product Information Request Actaris SL7000
You can use Gurux Device Suite or GXDLMSDirector to read meter.
sl7000 type sl761
sl7000 type sl761
hello,
Please, don't add the same question twice. I have answered for your question here:
https://www.gurux.fi/node/6528
