Introducing GXSerial
9 posts / 0 new
Last post
Gurux Ltd
GXSerial offers an easy way to build multithreaded, serial communication applications. Using the GXSerial component with different development tools, such as Access, Delphi, Visual Basic, Java or Visual C++ is very easy. With component you get a Visual Basic sample that shows how to use the communication technique. Gurux communication medias have been made on the Windows API interface. Due to this, the components are very efficient and do not require external libraries or DLL files to operate.
AhmedAlanee
You said "multithreaded" ,is there a demo for that ? thanks.
Kurumi's picture
We do not have demo. What programming language you want to use?
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
AhmedAlanee
C#.Then is there any sample code , tutorial ,documentations ?
thank you.
Kurumi's picture
For C# it's easy.
You just lock component like this.
GXSerial serial = new GXSerial("COM1");
lock(serial.SyncRoot)
//Send data what you want to send.
For sync send you can do like this.
lock (serial.Synchronous)
ReceiveParameters<string> p = new ReceiveParameters<string>()
Eop = Terminator,
WaitTime = WaitTime
serial.Send("Hello world!", null);
serial..Receive(p);
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
TaeSoo_Han
Sir, Do you have delphi source code about SNRM, UA, AARQ, AARE, Get-Request, Get-Response?
If you have, please let me get it.
Thanks a lot.
Thank a lot
Kurumi's picture
Dear Sir,
Please, if you have a new question, create a new topic.
You can get source codes to Delphi from GitHub.
https://github.com/Gurux/Gurux.DLMS.delphi
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
faijal
I want to connect multiple meters to the dlms-master via a single serial port.For that I am using RS-485 as it is designed to communicate between multiple devices connected to a single data line.So what modifications are needed in dlms-master(gurux c library based) application?.
Best Regards,
Faizy.
Kurumi's picture
Hi Faizy,
Please, if you have a new question, create a new topic. I'll answer your question there.
http://www.gurux.fi/ForumRules
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
