Connect
6 posts / 0 new
Last post
rikfro
Connect
If I first do add (tcp) and after that connect in the GXDLMSDirector I get an exception saying - exception "Client is unknown." on line m_Cosem.SNRMRequest(); Have I done something wrong?
Gurux Ltd
Some further information needed
Hi rikfro,
welcome to GuruxWeb!
To be able to help you with this, we'd need to know the manufacturer of your device that you are trying to connect to.
rikfro
Simulator
We are waiting for hardware and just wanted to evaluate our options. So we only opened a port and thought that GXDLMSDirector should send at least one message. Is it possible to simulate a meter in any other way?
Kurumi's picture
Hi,When you have new device,
Hi, When you have new device, you must first set correct Client ID, Server ID and Is LN referencing used. You can set those values at Manufacture dialog.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
rinkoo161
DLMS Director in RS-485 network
i am using DLMS director to read meter from RS-485 network, I have set Physical ID to 2D and 9D. now the problem is when i send command to ant meter it doesnot respond.
Can any body tell me how to configure meters for RS-485 network and what settings i have to made in DLMS director.
Please Help.
Kurumi's picture
What device you are using (Manufacturer and model)?
In DLMS/COSEM protocol device do not answer anything if client or server addresses are wrong. So I believe that this is the reason.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
