I run into this error when running this command to start the docker
The command:
docker run --rm -it -e "Database:Type=SQLite" -e "Database:Settings=Filename=:memory:" -p 8000:80 -p 8001:443 -e ASPNETCORE_URLS="https://+;http://+" -e ASPNETCORE_HTTPS_PORT=8001 -e ASPNETCORE_ENVIRONMENT=Development -e ASPNETCORE_Kestrel__Certificates__Default__Password="123" -e ASPNETCORE_Kestrel__Certificates__Default__Path=/https/Gurux.DLMS.AMI.Server.pfx -v %USERPROFILE%/.aspnet\https:/https/ guruxorg/guruxdlmsamiserver:latest
The error:
Unhandled exception. System.ArgumentException: Data Source cannot be empty. Use :memory: to open an in-memory database
at System.Data.SQLite.SQLiteConnection.Open()
at Gurux.Service.Orm.GXDbConnection..ctor(DbConnection[] connections, String tablePrefix)
at Gurux.DLMS.AMI.Server.ServerSettings.ConnectToDb(WebApplicationBuilder builder, ILogger`1 logger) in /src/Gurux.DLMS.AMI/Server/ServerSettings.cs:line 748
at Program.<Main>$(String[] args) in /src/Gurux.DLMS.AMI/Server/Program.cs:line 95
at Program.<Main>(String[] args)
Hi, SQLite support is…
SQLite support is removed from Gurux.DLMS.AMI at the moment.
You can use MySQL, MariaDB, MSSQL, or Oracle SQL.
